roger 04 rt
When I first rode my 2004 R1150RT, one of its most startling characteristics is how rapidly it decelerates from cruise when you closed the throttle quickly. I have read that this function goes by various names but I'll call it Overrun Fuel Cutoff (OFC).
It is written that this function aids in fuel economy, recharges the Cerium layer in the CAT with oxygen, improves deceleration (you can say that ) and in some motorcycles, reduces exhaust system backfiring.
I was reading through my GS-911 data lists last night, a slow manual process, and made some observations:
--When you drop the throttle from cruise or acceleration, within a second, the fuel goes full off--nothing.
--The fuel stays off until the RPM drops to 1800 RPM and then the fueling pulses come back on.
--Fast idle, which is TPS=1.28 degrees on my bike and about 1500 RPM when warm, does not block OFC.
--There was no data above 2 degrees TPS that resulted in OFC coming on.
--When the engine is cold, OFC is still operational.
--If the throttle were dropped to 2 degrees open (as opposed to 0.32 degrees which is close throttle on my bike), it looks like OFC would not occur.
--If you drop the throttle, and then open it a couple degrees, OFC is canceled. (But feels a bit jerky to me.)
--Many times when we shift, the OFC function comes on for 3/4 second, give or take.
I think I've adapted to OFC fully with my driving style but I was used to motorcycles that lacked this "benefit".
