I just reassembled my '04 1150 GS after replacing the clutch disc. During disassembly I popped the circular top off the gear indicator switch on the back of the transmission. I did not make note of its orientation. I assumed it would only go on the correct way. It appears to be a bad assumption as despite placing it on in several different orientations I can't get the gear indicator to correctly identify the gears. It either displays 2nd and 3rd at inappropriate times or nothing. Any advise on how to correctly orient this will be greatly appreciated.
I did not remove the base plate for the switch, which I assume will come off if I compress the two short metal rods projecting from the rear of the plate. Should I do this?
Dave
Dave
