barron_williams
Monza Blue 1974 R90/6
I need some expertise/experience.
1974 R90/6. Been running super all summmer.
This morning after riding about 40 miles, when I pulled in the clutch as I was stopping for a red light, with the right turn signal on, the engine stopped, and I had no headlight, no instrument lights, no starter, nothing.
Put the bike in neutral, turned off the ignition switch, and pushed it off the road where I could look things over. Symptom was exactly as though the battery ground cable was loose. No electrical power at all.
Checked both ends of the ground cable (trans and battery), nothing loose. Spent about three minutes thinking about it, turned the ignition switch back on, and bingo!, oil, neutral, and charge lights lit. Pressed the starter, it fired right up, and I drove the 10 or so miles home. During the trip home, I stopped at several stop lights, used the turn signals, no problems.
Parked the bike in the garage and after a cup of coffee, I turned on the ignition switch (without starting the motor) and again, oil, neutral, and charge lights lit like normal. I pulled in the clutch, no change. Stepped on rear brake, no change. Pulled in front brake, no change. But, when I turned on the right turn signal -- lights out. Same symptom as before, as though I had no electrical power.
I checked battery, good voltage. I check battery connections, nice and tight. Checked ground on tranmission again, good.
Thought it might be the ignition switch (it is the original switch). Disconnected the red wire at the at the ignition switch (the one coming from the starter relay), approx 12 volts on the red wire. So, switch is getting power.
Disconnected the green wire from the back of the ignition switch (green wire goes from the igination switch to the terminal block inside the headlight shell). When the ignition switch is turned on, I have 12v between the spade on the back of the switch (where the green wire attaches) and ground.
So, not the iginition switch?
I pulled both of the 8A fuses, checked them (good), and cleaned up the ends.
No change in symptoms.
As info, overall, the electrical system is in ok shape. Over the years, I've cleaned up connectors, I've got star washers on the frame grounds, so I'm puzzled.
What component would fail, or which wire would break, that would cause the symptoms I described?
As additional info, because common wisdom is to always look at what you did last - I had the right turn handlebar assembly off about two weeks ago while I installed the tri-angle wedge that had been missing for 20 years. I've probaby ridden the bike eight times and several hundred miles since then.
So, I unfastened the right switch (removed the two small and one large screw) and can't see any broken connectors or piched wires. I also checked the handlebar mounted brake light switch and both wires and their connections look ok.
Not sure how a problem with the right handlebar wiring could cause the described symptoms, but that was the last place I was working on the bike.
And the one common thing is that the turn signal was on both times when I lost power.
The turn signal relay is the original. It looks ok inside, no visibily damaged components or sticking contacts. If it has failed, would it cause the symptoms I am experiencing; or, just loss of turn signals?
Any ideas?
Any recommendations where to check next?
Regards,
Barron
Any ideas?
Regards,
Barron
