OK, I bought a barn bike today
R
rbleau
My first post ! Although I recently joined MOA, my first BMW was a 1960 R60US back in 1972. Well, I retired from Lockheed last November, and I am an amateur wrencher - very amateur. Today I bought a 1977 R100RS that was last registered in 1987. The fuel tank is completely rusted out - it was parked with fuel in it. Otherwise it is complete, including tool kit and bags.
What should I attack first ? I do not know if the motor is frozen. It has oil in it an I do not see water. Just got it home tonight. unclear how to attach a photo...
Ready to get some good suggestions as I am sure you folks have "been there already". I elected to put some of my 401k into West German steel and aluminum rather than Wall Street. Thanks / Ron
1977 R100S - done
1977 R100/7 - in work at a shop
1977 R100S - awaiting work
1977 R100RS - today's bike.
Welcome Rbleau
Looks like you are embarked on a real adventure. You have come to the right place. There will be lots of advice coming along.
Come back here with stories and pictures as the restoration proceeds.
Paul
Disassemble. Inspect and repair or replace as necessary. Reassemble in reverse order.
Seriously, that's what I did.
But first - WE NEED PICTURES!
So you like '77s?
Congratulations on your find. I'm sure you'll get lots of better advice than mine, but I'm just getting into a barn bike (1971 BSA Lightning), as well, so here's what I've learned.
Patience is your watchword. Dose everything in penetrating oil and then dose it again and let it sit. The quaint old English name for the stuff is "easing oil" and that's exactly what you want to do, ease it.
Try to turn the engine over by hand, gently, so that you don't bend a pushrod getting it loose. Take the spark plugs out for this, pour in some of your easing oil of choice, leave it for a day to work into the rings. Take off the front cover to get a purchase for turning. When it turns, you might be able to feel any stiffness or gravelly feeling, which of course is bad. If it comes smoothly and you can shift the gears (spin the rear wheel while shifting) and they feel good, then why not change all the fluids, borrow a tank and battery and see if she'll start. That will tell you a lot of what you need to know.
If it won't turn, then I would suggest you start from the top down, heads, barrels and, finally, the bottom end.
Watch for water in the transmission.
There are several good books on restoring old bikes that have a wealth of practical advice, including how to work around a lack of factory tools.
I have a 1977 RS. I guess '77 must be the best year, no?
Good luck,
Tony
DON'T start the bike, if the motor turns I would drop the oil pan and clean it out along w/ the strainer. Gets rid of any sludge that might have accumulated over the years, plus lets you see if anything is obviously wrong. Change all fluids, brakes too, at least drop the fuel bowls, but will most likely need to pull the jets and clean them too. Check fuel lines for clogging (maybe go ahead and replace) and replace fuel filter and clean petcock strainers.
Good thoughts, Tony. I had been hinking od trying to turn i via the rear wheel....maybe not. Yes, I think 1977 is a very good year. I like double disc brakes, for example. "easing oil" - gotta buy some of that ! :)
Cheers, and Thanks, Ron
Good luck,
Tony
Thanks, krehmke, and to all I apologize for my fat finger typos in prior reply. Here is a pic. Thanks / Ron
Nice machine. It should be a lot of fun getting it into shape. Mine was in similar shape. Count on replacing EVERY piece of rubber. All grease (steering head, wheels, swingarm) will have turned to hard grunge. Inspect your wiring harness very carefully. Look for evidence of rubbing, corrosion and melting, especially below the starter relay (a problem spot on these). Check carbs for correct jets and rebuild them. Brakes are likely needing complete overhaul. Hopefully the master cylinder will save. New hoses, rebuild calipers. Forks will likely need cleaned out and rebuilt as the internal dampers will have turned to sludge. I found Hucky's BMW a good source for ignition, brake and fork parts/kits.
Ask questions. There are lots of folks here who've been there done that and are willing to share their experience.
Most important: HAVE FUN!
Before you spend much effort/money pull the oil pan. There was was a case of an old neglected bike posted here a few months ago.
After much work and an entertaining narrative, he found big chunks of metal in the oil pan. He hasn't posted in a while, but I think he abandoned it.
Good point Ron. I'd forgotten the perils of "Renegade."
There's another thread worth looking at - it was captioned "Does this airhead make me an airhead?," and along with some good advice, it may cheer you up if/as you discover problems. They almost certainly won't be as bad as those of Renegade's owner (or as humorous. I'm not laughing at Renegade's owner's ultimate bad luck - we could all feel that pain - just some of the lesser travails along the way) .
R 50s
I have a garage find R 50S and spent the last year cleaning correcting and enjoying the sporty little machine. I would first strip all the plastic off the bike to ensure there are no rodents in residence, remove and clean-out the oil sump, remove and clean valve covers while you inspect and adjust as needed the valves, remove the spark plugs and add a good amount of "Marvel Mystery Oil". While this soaks and does its job remove the carbs and all the air filter plumbing for inspection and cleaning, you should plan on complete carb rebuild. By this time the motor should be free to turn by hand, before you install a good battery you should inspect the wiring harness to ensure the hungry & cold rodents have not chewed it up for a nest or food. Fresh oil, remote starter, carbs removed go ahead and run a quick compression test. Hook up the battery correctly and check the spark with new plugs. Now after all that has checked out good or been corrected put the rebuilt carbs on use a donor gas tank, fresh gas lots of ventilation and crank it up. keep fans on the motor to avoid overheating and run it on the centerstand at vareing speeds for about 30 minutes. check for leaks knocks and other signs of pending doom. Shut it down, let it cool and run another compression check if its decent change the driveline fluids, check the brakes, air-up and check the tire condition if it all loks good ride your still naked RS 100 around the neigborhood for about a half hour (Oh put a good tag on it) then bring it home let it cool and check for leaks, broken stuff and any other potential problems. Give the bike a good cleaning, fresh tires and enjoy it as a riding restoratin project.
ZEFF
My first priority would be to get the engine loosened up. I would remove the plugs and fill the cylinders with oil and let them soak for days. I'm fond of mystery oil. After it has soaked for days, then you can try and turn it. don't force anything. If it doesn't free up, I would remove the heads and try to pull the cylinders so I could clean themn up.
You've gotten a lot of good advice here on going stem to stern renewing and replacing things as needed. Being a novice wrench, you are bound to run into situations where you will need some advice. Coming here is a great place to get some advice, but there's no substitute for getting some one-on-one advice from someone who knows. If you haven't done already I would join the Airheads group (Airheads.org) and attend some tech days. Between here and the Airhead group, you should hopefully be able to locate a few local gurus who will be more than willing to give you a hand. And, if you've got a few extra $$ you don't mind spending to make a few new friends, you could always host tech day.
I look forward to watching this one.
Looks like the bad weather keeps coming, so you've still got time to tear it apart without cutting into prime ride-time.
:lurk
What the heck - enclosed is a photo of my 1974 R90/6 I bought new from Irv Seaver in Santa Ana in 1974.
Irv Seaver? I prefer Browns Motor Works!!
That mention and the picture of your brand new R90 bring back memories of bikelust. All that I could afford was a Honda CB500T but I used to visit Bob Brown's and Irv Seaver's and drool! Eventually I got my used R75.
Interesting bike. If I am seeing what I think I am, then Bill Stermer's R100RS book has a picture of what he suggests is the only R100RS with spoke wheels and a rear drum brake that ever made it into the US, may be mistaken. All others had rear discs. Apparently, there are two??? Anyone else have a drummy RS too?
Either way, it looks like a great find! Congrats and welcome.
My '77 RS has a rear drum.
What's the serial number of the new acquistion, rbleau, if you don't mind sharing it?
Hey, don't forget to put your info on the 77RS registry - and get a 77RS t-shirt and coffee mug. There are more of us around than you might think.
http://www.geocities.com/knut_brauteset/form.htm
http://www.geocities.com/MotorCity/Show/9544/rs77.htm
ADV (www.advrider.com) under 'Old Skool' currently has several individuals that are working on airheads. Several of the threads are being well documented with photos and comments.
http://www.advrider.com/forums/showthread.php?t=433588
http://www.advrider.com/forums/showthread.php?t=431153
http://www.advrider.com/forums/showthread.php?t=417387
