JimMoore said:I have been spending a lot of time at high rpm (6500+) on my oilheads. The valves have been changing (tightening up) to a much greater degree than they did when I rode at lower rpm. You might want to check them more frequently if you ride at high rpm frequently.
glwestcott said:Why would you ride at such high rpm? That's outside the power curve and simply going to cause more wear than necessary. Lugging is bad, but so is over-revving.
drrider said:the directions taken from the advrider forum was great, but leaves me with one question. can someone explain how leaving the timing plug out could effect the way the bike runs? mine's been gone for a long time
