We're certainly a nerdy bunch, no?
Theory is all fine and wonderful, but how about some actual testing?
How about a spring scale anchored to the frame at the rear of the tank to measure the amount of force ACTUALLY required to lift the bike off the stand? Checking from both sides, of course. While there is probably not much difference in tipover force required on the centerstand, on the sidestand is another story.
Just my thoughts,
I would imagine friction at the points of contact would weigh heavily into any literal or figurative equation. On the side stand my three points of contact are the side stand and two tires. Center stand; front tire and the two contact points of the center stand that are closely placed. The "maintenance" stand always feels unstable to me. It is necessary to access the rear wheel maintenance area. The side stand always feels very stable to me. Two years ago my bike was hit by a golf cart at work, it was on the side stand, the right rear wheel of the golf cart hit the right side of the front wheel of the bike. The OEM rain cover was on. The front wheel turned left with impact. No damage to bike no toppling.
Can you provide us with the algebraic formula that you used to calculate the side forces? Did you derive your final data from actual testing on your bike in your garage? I.e. tipping it and then using measuring devices to see just how much force is needed to tip back up or tip to the point of T/O?
Did you basically use these numbers:
Total weight of bike
Lean angle (theta per your sketch)
Location of the center of gravity (assuming centered over tire patch left to right, and then measured height off ground)
Could it be that you used some formula that was used for "leaning" forces while riding? I would think that they could be similar, as one can imagine the "forces" when actually leaning into a turn, for example and the "forces" needed to straighten it back up after the turn.
Just asking....
Thanks,
jlc
Jimmy -
I did think about testing to see how my answers compare. I envisioned a fish scale of sorts attached as suggested. It would be easy enough to perform the tests on my Reynolds stand setup, although if the correct answer is near 130 pounds, that's going to be a bit scary to do the test...even if it is just to get the bike to start moving. My stock centerstand is in the attic. As for testing on the sidestand, I'd have to wire the sidestand down and block the front and rear wheels so it doesn't move. I don't have any "built in" helpers, so doing it solo presents some problems.
That does it. I have read this entire thread. I obviously need help.
I am going to buy a 45 year old Puch 250 twingle for a Winter project.
That'll do it, I'm sure.
Thanks for stepping in and bringing a bit of reality to the situation.......God bless........Dennis
Neat looking bike. Wherever did you find a cutaway twingle engine?
