Jeff488
Aspiring Profligate
142k miles.
This is a friend's bike.
Died on the road. After cooling a bit, it restarts and runs for about 45 seconds.
Pulled the coil and noticed a very slight bulge and a separation where the epoxy joins with the edge of the black plastic body of the coil.
Secondary coil read 7390 ohms; primary reads 1.75 ohms. Used two different VOMs.
AFIK, it should be 15k and .5 ohms, respectively.
Am I on the right track thinking the culprit is the coil?
Also, should we rewire the HES as long as we are in there?
TIA,
Jeff
TIA,
Jeff
