I have a Brown side stand and love it. It is very easy to install, easy to deploy and very heavy duty. The only downside is that the "foot" is not large and will sink into asphalt and dirt. Kind of expensive for what is essentially a super heavy duty bicycle stand but well worth the money. Can be found used on Ebay however.I have a 92 rt and struggle with the stock side stand. What is your opinion of the Brown side stand and the difficulty or not of installing it.
Ditto thatI have installed them on just about every airhead that I have owned. They are well worth the money and easy to install.
As I recall, the Brown is round rod. There is also another bracket that accepts a BMW sidestand in the footpeg area (where it belongs) with more of a foot. You can bolt a stainless steel strap around the bottom of the Brown sidestand to provide some additional area.
The designer of the stock airhead sidestands should be required to travel with a heavy pack on the back of the bike for 2 or 3 millions miles, so he would continually be catching the bike as the front wheel lifts off.
Be aware that the Brown (and other) sidestand bracket bolts on the end of the rear engine stud, and it might be necessary to find a longer stud. I think I got one from a Suzuki dealer. You don't want the stud sticking out more than a thread or two on either side, but you do want the threads all the way through the nuts.
And the front of the bracket is held from rotating by a strap around the header pipe. Take care to get the fit right so it holds the bracket firmly, but doesn't rattle on the chrome.
Depending on your style of shifter lever, you may have to file an indent on the top of the sidestand bracket to allow shifting down into first gear, and not having your toe slamming into the carb bowl on upshifts.
pmdave
The Farley is similar to the Brown's. But it already has the indent by the shift lever. And on the later ones the strap around the header is now a collar attachment to the frame. Also, you can order it with the longer stud.
I have these on 3 twinshocks. Don't know if there is a monoshock version, but it would seem worth a try - I bought one less than a year ago, so they are in current production, apparently.
I have a Brown sidesand on my 78RS and had one on my 95RT. On the 95 I mounted it differently than using the exhause pipe for support. I added an extension rod mounted to the first and a second hole that I drilled in the side stand between the two holes already there.
I then attached this support rod to the front engine mount bolt. I felt that this was more secure than the exhaust pipe arrangement. However, I have never had an issue with the 78 either. Sorry, I no longer have the bike or a photo of it.
I like the stand because it does not feel like the bike will fall over if pushed forward.
I really like the Brown over the stock, springer stand. Yes, you do need something for the bottom of the stand on the asphalt. I've got some little plastic discs given out at rallies. They even have little holes in them. Tie a piece of dental floss on it, so when you're ready to take off, you can just pull it up, wrap it up and put it in your jacket or tank bag.
