The same caution is in the '14 RT owners manual. Pretty amazing, a compartment for your electronic devices that they advise you not to use.My dealer advised when I got my GT to NOT put phone in right side compartment due to heat
Have a bar bag with cable to power plug no issues..
....My wife just got the 6 (Not the 6Plus) It fits in the slot in the foam (without any sort of case etc) I suppose the foam could be "altered"if you do have a case. And....yes....if you do go this route, I suggest a meat thermometer.....so you can pull it out before it gets "Well Done".
I personally don't use either compartment for anything that will "Melt"......It is rather piss-poor that they designed it as such......silly Germans.
Thanks!!!
Off to the apple store I go... And to Amazon for the correct connector
