R
RTFlyer
The amateur radios are a no no unless you are both licensed.
Just to be clear...FRS radios do not require an FCC license and may not be modified to increase range or signal strenght (boosting output or attaching external antennas) and shouldn't need to be when used as bike-to-bike comms. GMRS radios do require a license and may be modified.
I'm not sure what an amateur radio is by deifnition.
I have a Scala Q2 and it's adequate. I would go with a Starcom set-up if I had it to do over again.
