On the Hexheads, the QD isn't subjected to the same sort of heat. I have been upgrading them on a by-eye basis so far, but I upgrade all of the 11xx ones every time now.
HI, Anton, thanks for the input.
The term you use, "by-eye basis," does that mean you do not remove the tank solely to look for trouble, but if you have the tank off for some other reason then you will inspect and possibly replace?
John
