22600
rsbeemer
I like this explanation the best.
And I quote, "leave the clutch alone." That leaves all the guessing out of, engaged or disengaged.
DW
Keep in mind if you're turning and you pull in the clutch, it's similar to chopping the throttle and will decrease your control of the bike or even stand it up if leaned over. Swerving should be done with the throttle steady on and leave the clutch alone.
DW
