Battery
Until you cobble one up, or purchase one, your light bulb isn't such a terrible idea. Me? I'd go for something that consumes higher current, like a sealed beam headlight lamp. :idea
I use one out of the pile of headlights in my garage that were changed due rock chips and BB-pit-holes in the glass over the years.
The filaments are not as themistor-like as people imagine.
The lesson is that you certainly need to test more than the no-load voltage if you think you have a battery problem.
Well of course.
A complete battery test consists of a load test and a capacity test.
Even those "conductance" testers do not provide the whole story. I've connected them to batteries only to have them indicate a healthy CCA, battery voltage and even a "Good Battery" indication...this from a 100 Ah battery that only has 25 Ah of capacity.
Followup comments: The battery was branded Scorpion, model YT12CL, sealed AGM type.
That may be your problem, Paul.
Do you use this battery in Texas? Have you checked the battery voltage under various conditions when it is 100F outside? Chances are you are overcharging the battery and it is now dry. Now you know why I mounted a voltmeter on my GS and Porsche which is wired directly to the battery.
That is the problem with VRLA batteries; AGM or GEL. You can't afford to have them gas due to overcharging because what is lost cannot be replenished...as in being able to add distilled water as you can in a flooded lead acid battery.
Another fact about battery life, ever 8C (15F) increase above 27C (80F) decreases battery life in half. Run a battery in 110F temperatures and it lasts 1/4 as long as it does at 80F. Vibration is the other battery killer.
BTW, invest in a carbon pile 500A load tester from Harbor Freight. A load test is done at 1/2 the CCA rating of the battery for 15 seconds with voltage decreasing no lower than 10.5V...this test is done on a fully charged battery.
Paul, the following chart shows battery charge and float voltages based on battery temperature.
As you can see, you hope your voltage regulator temperature compensates. An on-board voltmeter will tell you that.
batteries
car's and bikes i change every three years, do not want to get stranded. that being said my airplane lives with a seven year old battery it gets a 30 minute charge every day. play it safe..
That seems a bit backwards. :D
Thanks for the chart Alex.
I bought the bike in November. I don't know what it did in its former life but the battery hasn't seen anything close to 100 degrees over the winter. It is not the first battery that has failed on us, and the failure wasn't totally unexpected. I do have a volt meter on the bike - full time. And I know that the cheesy charging system on F650s over cooks batteries.
What puzzled me was the failure mode. I've had the dread Yuasa snap-pop dead zero volts. I've had the slow but sure loss of capacity. But I have never had one act quite like this one did - described in posts above. I was trying to figure out the failure mode is all.
If you remember, what kind of voltages are you getting during cruise RPM and at what ambient temperatures?
Does it follow the charts or is the voltage quite a bit higher?
My diagnosis is that the battery failed, suddenly and totally. Yet it still showed a standing no load voltage of 12.7 volts. But it had virtually no capacity to power anything. It wouldn't power a tail light bulb, let alone a starter.
I wonder how it was a day before or a week before.
I suspect high internal resistance....all of a sudden? :dunno
I might do that some day. But right now I don't have an indication there is a real problem. I just had a battery of an unknown age fail. The voltage reading I am getting going down the road don't tell me it is overcharging. I haven't ridden the bike enough to know for sure how it is behaving. So, with a new battery I'll see what is going on and then decide whether it needs anything.
Thats OK.
Any ripple due to a bad diode?
Not that I have detected. But, I really haven't tried to seriously troubleshoot the details of the charging system because that never works well unless there is a good battery in the system - which there isn't yet. After about 2 days past when I expected the battery I ordered I inquired. And low and behold, the computerized "fulfillment" outfit messed up a bunch of orders over that weekend and Battery Stuff never got mine. So I talked to them over the phone and it is now headed here the fast way, with a free bonus T shirt to boot. I am not complaining at all about the service. Mistakes happen and then how you fix them is what matters.
Once the new battery arrives I will install it and then do a thorough check on the charging system but trying to do anything with a junk battery in there is futile.
