R1100RT
Looking for feedback from folks who have installed an auxiliary fuse block (fuzeblock, pc-8, centech, etc.) on a R1100RT to see where they have located the device on the bike. Thanks in advance.....
I have a Centech installed on my '99 R1100RT and it sits on top of my air cleaner box.
JB
Does that work with the seat in the low position?
I would have to say Absolutley !! as I have my seat in the low position with the CENTECH mounted on top of the air filter box.
NOTE: should you mount the fuse box here, leave enough wiring from the battery to accomodate the lid when removed from the air box.
Here's a pic of mine......it also shows the external fuel filter mounting as well
Where did you tap in for your 12 V relay signal? Bob
I don't think most accessory fuse blocks are waterproof, so keep that in mind too when choosing a location.
