Results 1 to 15 of 19
Thread: reduced oil change intervals for 1150s?
    On the Road
    PVD.RI
    I was talking to a friend who just purchased an 80th ed rockster. Nice bike. Anyway, she mentioned she was going in for an oil change, which surprised me, because I didn't figure she'd ridden 5400 miles in the last two weeks without me noticing. And she hadn't. She said they are recommending 3K oil changes for the bike.
    1. Is this correct?
    2. Is there something different with the rockster than all the other r1150s?
    3. WTF???? This would mean an oil change every week for some people. It can be hard enough doing it every 6k.
    Can anyone set me straight on this?
    Megalodon fish's Avatar
    Gold Country
    Sounds like a dealer revenue-generator. What does the manual say?
    "No one wants advice -- only corroboration." -John Steinbeck
    Like San Jose BMW Motorcycles on Facebook.
    pdx
    2nd point, if you're riding enough to 3k happens once a week or two, you're riding in such a way that you don't need to change the oil very often.
    On a long long trip, you can easily extend that service interval, IMHO, without worry. The clearest way I think of it is that you need to change the oil after a certain length of time or after a certain number of cold starts.
    El Dookey loves to ride. 99007's Avatar
    Aug 2003
    Ada, MI (outside Grand Rapids)
    Nobody told me any different
    I bought a Rockster July 8th. My dealer (in Grand Rapids, MI) did not tell me a different schedule for oil changes. It was the same as my 01 R1100RL. 600 miles, 6k, 12k etc.
    I will check my manual when I get home tonite, but I think your friend might be getting a bunch of hooey from the dealer.
    I just went over 3k this weekend and I am not changing the oil!
    Don't winterize; Rounderize!
    www.yearroundriders.com
    Rally Rat MarkF's Avatar
    Connecticut
    A lot of guys brag about doing an oil change every 3,000 miles, like it's a virtue. Some dealer probably jumped on the band wagon. As far as I know all oilheads are every 6,000 miles or every year, whichever comes first.
    MarkF
    On the Road
    Aug 2003
    Idaho Panhandle
    reduced oil change for 1150's
    My dealer (Beaudry in Post Falls, ID) mentioned the 600, 6k, 12 change to me and then suggested I change it in between those scheduled changes. He said the oil is cheap (don't know, haven't bought any) so why not do it.
    '04 GS
    GSer JERRY's Avatar
    Ohio
    wow! hasn't this been going on long before we started riding? think the key word here is "recommending".
    if you want to change it @ 1000, 3000, or 6000, then that's what you should do.
    any of the above works just fine.
    comfort level.. folks.
    RIDERR1150GSADV
    Talking oilchanges
    IMHO I think that 6 K is a normal interval for an oilchange on R bikes. My dealer did suggest to change the oil at 3 K in addition to the 600 mile change, since I was braking the engine in. This was the only additional oil change I ever needed to do:cool:. I did the same with my truck and 4 stroke outboard.
    In any case withe the modern oils available it is not nessecary to overdo the changes and dumping extra oil in the environment. If a Porsche can get a 15 K interval on synthetic oil, our bikes ought to do well at 6 K.
    TooManyToys
    I'm more comfortable with 3K changes. Heck, most cars are 7500 normal service / 5000 'rough' service for oil changes.
    I go with the "oil is cheap" theory, changing it myself between the 6K, 18K, 24K, etc. services.
    GIZMO
    The BMW service interval including oil & filter changes is 600mi, 6K & 12K. I believe your friends dealer was only "recommending" changes every 3K. This is not bad advice, because the acids that accumulate in the oil are removed sooner. With K & R motorcycles you do not have to change the oil filter during these between service oil changes because there is very little metal debris produced. Where as in the F650 series there is a higher content of metal filings produced and therefore a good idea to change oil and filter on in-between oil changes. If however changing every 3000 K is too onerous, you will still be compliant for warranty purposes with BMW if you meet the 600 mile, 6K & 12K service intervals and many folks have had their motorcycles last many miles using the required service schedule.
    Loose Cannon flash412's Avatar
    Northern Colorado
    Where did you get that silly idea and does anyone have any evidence to back it up? I've cut open a dozen or more used airhead filters and three F650 filters. I found LOTS more swarf in airhead filters at 3,000 miles than I've ever seen in a F650 filter at 6,000 miles.
    BTW... if you think you need to change your oil at reduced intervals, you are probably wrong. Why not do an oil assay and find out? Here's one of mine with 7000 miles on the 5W50 Castrol Syntec oil from my F650 .
    Click here for Tales of Motorcycles and Life
    - BMW MOA Lifetime Member #18854
    RIDERR1150GSADV
    Cool oilchanges
    Well it seems that most people agree that changing oil more frequently than recommended is not bad thing.
    If you change oil more than the manufacturers recomended service intervals, it certainly will not hurt. It actually may help you if anything goes wrong with the engine if you keep all receipts.
    The only thing I always do is also change the filter anytime I change oil. On my Suzuki outboard motor that is recomended too but on my Yamaha outboards it was ok to leave the filter in for another 100 hrs of operation, something I never did. I never understood why and the dealer could not explain this either.
    I do think however that the service life of synthetic oil is much better than that of natural oils and I personally don't have a problem leaving the oil in a little longer than 3000 miles. The oil is not what breaks down but the additives do and there in lies the problem. So buy a good quality oil and enjoy the ride.
    BTW I think it was sportbike magazine that did an extensive test on oils in their Sept issue. I hope I got the right magazine I just got a glimpse of the article.
    GIZMO
    Two sources, a couple of well respected mechanics in my area who have taken the time to cut open some F650 filters and have found them to be more laden with metal filings. Second, From personal experience with two F650's, a K1200LT and a R1100S. When I change the oil there has routinely been a good deal more metal filings attached to the magnetic drain plugs of the F650's than on my recent K1200LT and R1100S both of which also had magnetic drain plugs.
    RIDERR1150GSADV
    Smile
    Maybe there are more filings on a single cylinder engine than on a two or four cylinder engine as the single needs to work harder than the others to perform the same ., I don't know for sure but if one feels more secure by changing the oil more often, than by all means do it.
    I will monitor what goes on in my engine and act accordingly but so far I have not found any shavings or particles at all and that is good .
    In any case everyone should keep an eye on their engine and act accordingly to prevent major surgery later on.
    Well that was my 2 cts.
    Northern Colorado
    Did they ever cut open other filters and NOT find them to have metal filings? As I said before, I cut open lots of filters, F650 and airheads. I certainly don't see any more swarf in the F650 than the airheads.
    Your anecdotal comparative evidence for oilheads and K-bikes does not match my anecdotal comparative evidence for airheads. The first few oil changes on any motor have the most swarf in the filter and on the drain plug. A later increase in the amount of swarf is an indication of wearing off a part, such as hardening suddenly going away. Obviously this varies on a case by case basis. So much for anecdotal evidence. No blanket statements are accurate without a significant statistical sample, which clearly neither of us has.
