Results 1 to 5 of 5
Thread: disassemble the parts
    On the Road
    Jul 2003
    Lawrence, KS
    I bought a new petcock to replace the old, that's point one. Point two is that I bought new gaskets to replace those contained in the old petcock.
    The problem you ask?
    How do I get the plate to unscrew from the main body? There are two slits, but I do not have a "tool" that will allow me to secure both sides so I can turn the face to change the gaskets.
    Help!
    Thanks.
    On the Road
    Jul 2003
    Lawrence, KS
    Someone has taken apart a fuel petcock; How did you unscrew the face? I have it my hand, but I cannot get a grip on the slits to open the face to repair the gaskets.
    Loose Cannon flash412's Avatar
    Northern Colorado
    Take two screwdrivers with tips that fit the slots. Put one in each slot. Put a third across the middle of the first two, to form a sort of an "H" in your hand. Unscrew it a bit. Depending on the petcock, you MIGHT be able to grab the "lip" of the part that unscrews with slip-joint pliers. Certainly after you unscrew it a turn or three you can.
    Click here for Tales of Motorcycles and Life
    - BMW MOA Lifetime Member #18854
    On the Road
    Jul 2003
    Lawrence, KS
    Thanks. I will give that a try. I was trying a "chisel" approach with a mallet and screwdriver, but no dice. This may show some promise.
    Registered User MTHelmet's Avatar
    Danielsville, PA
    Lightbulb
    I use a needle nose plyers, with long njose, so thast it reaches over the center. Then turn away. Careful when it come apart, there is a spring washers under it.
    MT helmet
    [COLOR=Red]NO ONE ELSE ADMITS IT[FONT=Courier New]
