Need a battery
Kev95gs
goob
Hello All,
I need a new battery for my 95 1100GS. Any suggestions ofa good source on line? Would probably like gel and not particular about "genuine" parts.
Kevin
battery
I would go for the BMW gel battery they used on the late 1150gs. Mine was about $5 more than a lead acid battery. They handle abuse well and should last about 8 years.
Odyssey Battery
The Gel batteries have not proven to be nearly as long lasting as the Absorbed Glass Matte types like the Odyssey. Both are sealed but the Gel is much pickier about the type of charger that can be used on it and you can easily over-cook it if you use the wrong one. They also deliver more cold cranking amps than the gel or a lead acid battery. I own three Beemers and all three have the Odyssey and I have experienced ZERO problems.
I have read many posts of others having the exact experience as mine on other BMW forums. Odyssey batteries are now being specified by the military because of their robust nature. They have a two year, full replacement warranty and it appears that they will last for 7-10 years if you keep it charged when you're not riding. As you can tell, I'm sold on their technology.
You can buy the Odyssey on Ebay for around $78 including delivery to your door.
SCjack-I think the jury is still out on GEL vs AGM. You are correct that the GEL requires a charger that doesn't go above 14.4 volts; however, Battery Tender sells them for about $45 with a 10 year warranty--exact same charger with BMW logo can be purchased from BMW for somewhat more. I have a GEL and am going on 3 years with no complaints. The AGMs will behave better in freezing temps but the GELs will last longer without a charge. At the last BMW RA rally guy giving seminar on batteries and chargers wasn't really high on GELs vs AGM, but don't remember why. He did say he preferred Panasonic AGM over other brands--again I can't remember his reason. The fact that the military buys Odyssey batteries may be more about a low bid than reliability.
The biggest endorsement for the AGM vs Gel is bmwsporttouring.com. They have been a gazillion posts on their site in numerous threads where riders have had premature problems with the GEL battery that came as standard equipment in their new bike so they replaced them with the Odyssey and have experienced no problems with better starting than they had experienced with the GEL. They have over 9000 members and are a very active site re. BMW oilheads.
I've had one of my Odyssey's for almost four years and it works like new.
I haven't tried the Panasonic but I have read that it is also reliable, but I've only read of people using it on this site (and no others) which has a limited number of users compared to a couple of others.
As for the military using the Odyssey. They are buying them due to the cold cranking amps and the reliability.
Just passing along usefull info based on personal use and that of 1000's of others.
I have no personal stake in whether you use it or disregard it. :bikes
SCjack,
I regularly read posts on advrider and sportouring, and am familiar with the reported failures. I, however, am reluctant to paint the GEL with a broad brush as bad without a little more detail on why people reporting failures had a problem. Initially there were a lot of people with GEL batteries who did not understand the charging differences from wet cell and AGM--not sure I would consider those situations as a GEL failure. Perhaps with a little more info the gazillion you cite may be a more believable 100. Like yourself I've got no dog in the fight, and like yourself I've got a battery with which I've had no problems........ but it's a GEL. Years from now I may come back to this thread and say you were right, but only time will tell.
need a battery
I have an Odyssey in one of my RS's, an airhead, and it works well. I have been told that when the non-wet cells fail or come to the end of their service life, they give you no warning.
Is there any truth to this? And how do you moniter remaining battery life?
Rinty
I bought the latest BMW Gel battery for my '97 RT 20 months ago along with the required new Battery Tender (less peak charging votage). Now the telltail signs of a bad battery are back. This is after and during a 300 mile ride. Slow crank, flashing ABS lights. I even put the Tender on overnight to rull out the alternator. This battery gave me less service than the Westco it replaced.
Note to self: Order the Odyssey, mount it sideways
My brother has been an electronics engineer for almost 40 years. While waiting on another assignment he did a brief stint in a division that made batteries and chargers. He is a great source of information and doesn't complicate making a peanut butter and jelly sandwich, i.e. good practical smarts.
So I posed the question about chargers and gel cells. "As long as the charger is reasonably sophisticated, at least as smart as the charging system on the bike, I should be OK". Those chargers that just cook along at 14 V without any regulation aren't good for any battery. He is a real fan of the Vector brand of chargers. I got one and really love it. The desulfation mode does help.
As far as batteries go, AGM is the only way to go. That's why I'm on line, to figure out what brand and where to order the replacement for the 5 year old lead acid BMW brand battery I've got now,
My two cents worth
Tom
My two cents worth
Tom[/QUOTE]
Just curious Tom, what was his expert opinion as to why the AGM was so much better? Or rather what was wrong with GEL?
Thanks,
Andy
Forgive me if I don't exactly get this right as I'm kinda old and trying to remember the details of a conversation froma while back. I've slept since then, but the jist (sp) of it is the gel cell is very similar to a standard lead acid except the acid in the battery is in the form of a concentrated gel instead of the watery fluid. I'm sure that there are some other differences in the construction... The AGM is a sandwich roll of the lead and a impregnated or soaked material for each cell. If you unroll one of these cells you can get an idea of how much surface area there is compared to the "stack" of cells in a typical batteries.
I'm gonna try to hook up my brother with this thread so he can straighten this out so that I don't screw it up to bad and we can all get it straight from the horses mouth. :banghead
Thanks Tom, that will be interesting. I knew what the physical construction differences were, I was very curious as to why he thought so emphatically that one outperformed the other. As you pointed out maybe it is the action of the surface area as that is where the chemical reaction would take place.
Thanks again Tom,
Andy
Rinty- I attached a very small digital voltmeter (C-volt. model CV100C http://www.i4cproducts.com/c-volt.htm) to my dash and it basically tells me when the bike is sitting the state of charge of battery and when running how well my alternator is doing. Can't say for sure because haven't had battery start to die; however, I suspect I'll either see the battery unable to fully charge or drop below normal when cranking ( now dips to about 10 V then jumps back up). If alternator is going i should see less than optimal charging when running or excessive drop in voltage when I turn on accessories.
Andy
You're right, surface area is the big part of the AGM. There is a lot of other "wisdom" that I hope to get from my way smart big brother that I'll try to pass along. One interesting thing that he mentioned is that he actually looks at the weight of a battery. Heavier being better. Kinda counter intuitive to a motorcyclist. By the way he rides an ST1100, but I don't hold that against him. :nono
Tom
Tom,
I'm looking forward to input from your brother. My limited understanding of batteries is that even though we talk about a "wet cell", AGM and GEL, they are all wet cell batteries as opposed to a dry cell battery--like in your flashlight. Difference being that traditional wet cells have liquid sulfuric acid electrolyte between plates; whereas, AGM has the solution in a fiberglass-like matrix and GEL has a thick solution because of silica(?). I do not believe the surface area of the lead plates is any different, hence, why they are all 12 volt batteries. The advantage of GEL batteries, as I understand it, is they can tolerate a much deeper discharge without sulfation and because of this there prime use is in marine applications.
The comment on the surface area alone would not necessarily change the voltage, although if the surface area is greater it will provide more of a "well" to draw from and that may be where the greater resilience to low charge over a lead cell battery that has a lower surface area of contact. I can't wait to hear from the pro though, at some point my gel will need to be changed.
Andy
battery
PetDoc: Thanks for the info; that'll go into my binder.
Quite frankly, when I have to replace the lead acid battery in my '02 1150 RS, I will be tempted to just get another one. With the fuel injection, starting is never an issue, and you've got an alternator which kicks out as much juice as a Volvo unit. And every four years, just replace it with another one, whether it needs it or not. I got stuck with a bad battery 2 summers ago, and it was a memorable experience.
On the other hand, I think that installing a gel/ABM battery is the single most beneficial improvement you can make to an airhead. Their alternators output fewer electrons than a couple of overworked fireflies, and if your state of tune is less than Parkhousian perfect, you may not be able to get a start at your high Rocky Mountain campsite, even in summer.
And I hate doing bump starts.
Thanks for the great thread you guys; this has been one of the best.
Rin
Hey guys,
I finally got an answer from my way smart big brother. Here is the e mail that he sent me
Tom,
Both AGM and Gel batteries are better than flooded lead acid in terms of resistance to abuse in the form of storage without charge, and resistance to sulphation. Flooded lead acid works great as long as it's used frequently and never allowed to over-discharge or sit for long terms without charge. Gel would be competitive with AGM but for the fact that Gel is more sensitive to over-charge. The charge voltage for Gel is lower than AGM or flooded lead acid. Since nearly all vehicle charger systems are designed for flooded lead acid, they tend to over-charge Gel batteries resulting in reduced life. The thin separator created by the glass mat in AGM batteries results in a very low impedance battery (this means high peak starting current). I have seen automotive AGM batteries with specified internal impedance on the order of 3 milli-Ohms (.003 Ohms). This means low internal loss during both charge, thus higher terminal voltage on discharge at high currents, and also less internal heat buildup. Motorcycle batteries won't be this low, but are still better with AGM than with flooded lead acid or gel.
One way of gauging the technology is to look at manufacturer's warranties. This gives an idea of the confidence level of the manufacturer. I bought an AGM battery for my car with an 8-year warranty. You won't find an 8-year battery in any other technology as far as I know. To me, this means the manufacturer knows this is a good battery.
Look at these sites for more info:
http://www.batterystuff.com/tutorial_battery.html#3
http://www.dcbattery.com/agmtech.html (Read this one for sure)
(Also read this one for sure ... very strong argument against gel)
http://www.windsun.com/Batteries/Battery_FAQ.htm#Gelled electrolyte
Finally, this site:
http://www.batterystuff.com/motorcycle-battery-value.html
Batterystuff.com sells several brands of AGM battery that they consider "premium". They do, however, distinguish the Odyssey and SVR as being "super premium", i.e. better than the rest. If you want the best, try to find an Odyssey or SVR brand AGM for your bike.
I haven't been able to find a cross reference to the Odyssey or SVR for my ST1100, so will probably buy a WestCo.
Good luck,
Jim
I think this should help edumacatum us a little bit. I was leaning towards the Odyssey but now I'll have to check out the SVR. Can't say that I've ever heard of it.
Good luck,
Tom
batteries
The sensitivity to over-charging is presumably one of the factors in the early failures of the gel batteries, as posted elsewhere.
The scenario that occurred to me is where the purchaser of a new gel battery equipped BMW brings it home and, thinking that it has been sitting around for half a year, hooks a high output car/truck battery charger up to it to just "top it up." All before reading the owner's manual, which presumably has a warning in it.
Rinty
I've read several articles that state that Gel batteries are also more prone to fail from exposure to heat than the AGM types. I would suspect that heat rising from the engine to the bottom of the battery may be contributing to the failure of some of the Gel batteries.
