Results 1 to 15 of 29
Thread: Pre-trip check
    Mar 2016
    Los Angeles
    Pre-trip check
    I am planning my first 1000+ mile trip since getting my '98 R1100RT (56k) earlier in the year. It has been running great.
    At the end of 2013 (55892 mi), it had the following done:
    - trans oil change
    - final drive oil
    - new plugs
    - alternator belt
    It was then ridden maybe 500 miles until...
    At the end of 2015, it had the following done:
    - ECU changed
    - new fuel pump
    - new breather tank hoses
    - plugs replaced
    - Oil and filter change
    - Valve adjustment
    Then I bought it and have put about 2k on it since February; it now has 58600 mi.
    I would love some input on what I should check before I head out. I know to check oil, tires, brakes and shock preload, but is there anything else recommended?
    Thanks!
    Left Coast Rider
    Nov 2011
    Quote Originally Posted by mtlla70 View Post
    I am planning my first 1000+ mile trip since getting my '98 R1100RT (56k) earlier in the year. It has been running great. I would love some input on what I should check before I head out. I know to check oil, tires, brakes and shock preload, but is there anything else recommended?
    Thanks!
    Has your HES (Hall Effect Sensor) been upgraded/rewired?
    Mar 2016
    Los Angeles
    Quote Originally Posted by BC1100S View Post
    No, I don't believe it has...
    Left Coast Rider
    Nov 2011
    Well, if it hasn't already, you DO want to get this done. There are people on this forum who can do this for you at a fraction of the cost a dealer would charge. And, using simple hand tools, its really quite simple to remove and replace yourself.
    Also - stop messing with it two weeks prior to your trip....
    Tom Barrie
    http://bluegrasspicker.blogspot.com/
    2012 K1600GTL
    2002 R1150RT (sold)
    OldBMWMaster JDOCKERY132445's Avatar
    Sep 2010
    Pleasure Island. NC
    HES...Spare
    GSAddict here does mine. I always carry a spare. I have had to use one on my bike and I have been able to help others out who did not have a spare with them.
    Jerry Dockery
    309 N. 3rd. Ave.
    Kure Beach, NC 28449
    1996 R1100RT main bike & 1985 K100RS...too fast to believe.
    Mansfield,MA
    Quote Originally Posted by bluegrasspicker View Post
    Some wisdom right there.
    Mod Squad
    2009 F800GS 1994 TW200
    Debbie's Servant Lee's Avatar
    May 2003
    SW Iowa
    How old are the tires?
    There's a 4 digit number on the side. First 2 numbers are the week, last 2 numbers is the year.
    Lee
    2016 R1200RS
    MOA # 30878
    MOA #24991 Pauls1150's Avatar
    Apr 2008
    south of Los Angeles
    The tension on the alternator belt should be checked about 6,000 miles after installation.
    After that, no further checks necessary until it's time to R&R it again.
    Pepperfool GSAddict's Avatar
    Feb 2008
    Sechelt, British Columbia
    Quote Originally Posted by Pauls1150 View Post
    I check them after 1000 miles if possible. They do stretch slightly initially and will squeak on cold startup if not re-adjusted.
    It is interesting the the OE manual has the following stated:
    Renew Poly-V belt *)
    renew Poly-V belt every 60 000 km (36 000 miles); do not adjust
    Ufda happens..........
    Bluenoser
    Mar 2010
    Lethbridge Alberta
    With that kind of miles check for play on the rear wheel, pivot bearings etc. Bike on centre stand, bike in neutral, put your hands at the 9 & 3 o' clock position and push and pull to see if there is any play, and then place your hands at the 12 & 6 o'clock position, push and pull and see if there is any play. If you feel any sideways or up and down play, then do a search on this site or just use Google. Lots of info out there on this topic and no need for me to repeat.
    If everything is fine with the above checks and the pivot bearings haven't been physically checked, in the life of the bike, then put that on your to do list when you get back. Enjoy your trip.
    1999 R1100s
    Aug 2013
    Bedford, Nova Scotia
    If I read your post correctly, it appears that the 2013 (55892 mi) service was done prior to you buying the bike. It did not include a brake-fluid change and there is no mention of one since, so we should likely assume that the brake-fluid is at least 4+ years old.
    Time for a fluid flush/change to be on the safe side. as much to avoid/stop internal corrosion from moisture contamination as anything else.
    Regards, Alan
    President BMWONS - MOA Charter Club # 097 / BMW MOA # 190956 / Airheads # 14457
    Current: '14 R1200RT / '06 Ducati ST3s / '86 R80RT / '75 R90S / '73 850 & '70 750 Commando Prev: '04 R1150RT / '81 Honda GL1100 / '77 Suzuki GS750 / '73 Norton 850 Commando
    Feb 2008
    Quote Originally Posted by AlanColes View Post
    If the bike still has the original black rubber lines they should be replaced with SS Teflon ones before riding anywhere.
    These rubber lines are a major safety concern - they either balloon without warning and/or deteriorate inside and block the braking system & ABS Pump.
    Mar 2016
    Los Angeles
    Thanks for all the input. Very helpful..!
    Also, upon checking to see if there was any play on back wheel (none!), I noticed that the rear tip of my right side footpeg mounting plate is snapped off (a previously unnoticed result of a little accident I posted about a few weeks ago). It is all good, except that the little support for the bottom of my side case is now gone - the truck that swiped me hit the side case and I see now that it broke the tip of that plate.
    Anyway, the case is still on there strong, but it hangs just a bit closer in than it had. It doesn't seem like a big issue, and I would rather not spend the $430 for a new plate. Can anyone think of a way to rig a little extra support until I can find a used one? (Beemer Boneyard etc have none in stock)
    Thanks again!
    Feb 2008
    Thanks again!
    Pictures of where its broken off would help.I have repaired a couple with aluminum backing and SS pop rivets.
    It also can be welded with a new piece, I can send you the plastic cap for the cost of postage.
    You may want to email Joshua Buck and ask if he has a used one. I have sourced used from him. Good guy.
    PM'd you his email
    Another place to check - http://www.re-psycle.com/
