Results 1 to 6 of 6
Thread: 502 bad gateway message
    Jan 2008
    El Paso, TX
    Why am I getting this message when I try to follow a thread--sometimes but very frequently...
    Larry Johnson
    Administrator 20774's Avatar
    Larry -
    This does come up once in a while. The last discussion was here:
    http://forums.bmwmoa.org/showthread....et-Bad-Gateway
    Usually the issue is needing to clean things up. Check what was written before and give it a shot. Let us know how you make out!
    Jan 2008
    El Paso, TX
    Simply logging off appears to have cleared all cookies . Thanks
    Larry Johnson
    Mansfield,MA
    Quote Originally Posted by ljjohns View Post
    Larry Johnson
    Mod Squad
    2009 F800GS 1994 TW200
    Jan 2008
    El Paso, TX
    But I got to thinking about this after my experience: when I posted the query under this heading, the problem precluded me from seeing your response, because I would just get the same message about a bad gateway. Did do a very laborious workaround to find the response.
    I'd suggest that you formulate a sticky about the issue that folks could access when they're having this problem.
    Larry Johnson
    Mansfield,MA
    Larry Johnson
    Well.......hate to say it but very few people read stickies. It's generally found that a read through of a section of the forum helps, even if one has to go back a page or two.
    A good rule of thumb on "puters, when there is a problem, try it from another device- such as a smartphone. That will eliminate login considerations real quick.
    Of course there are some that have remained logged in for so long they have forgotten their PW.
    Your back in
    Gary
    Mod Squad
