Results 1 to 12 of 12
Thread: Aftermarket brake pads?
    Mar 2007
    Colorado Springs, CO
    Are aftermarket brake pads better or worse than OEM brake pads? They sure are a lot cheaper. Thanks, Dave
    Mar 2010
    Vancouver, B.C. Canada
    EBC have worked well for me for years. Organic type and same as BMW and if you want longer life get the sintered versions however they will wear your rotors a little quicker as they stop more aggressively. I prefer the organic type on my 1100RT.
    PS: stating the year and model of your bike with questions is highly recommended or you just get generic guessing which is often off the mark and not helpful.
    Also helps to fill in your user profile with your location so that people local to you can offer help and suggestions. Some might even come over and help you! Most of us are old, retired and bored anyway...
    Apr 2016
    Roswell, GA
    EBC pads
    As Happy Wanderer says, EBC are good. Lots of forums will verify. Do your research.
    Save some money, look up your bike's pads on their website and order from amazon.
    IBA# 5819 61996's Avatar
    Mar 2014
    Apple Valley, MN
    EBC on every BMW I've owned.
    If life throws you a curve; lean into it.
    Mar 2007
    EBC is for me. Thanks guys for the info. Dave
    Northern Front Range, CO
    EBC HH is what you want.
    Ride Safe, Ride Lots
    Nov 2007
    Quote Originally Posted by joannmax View Post
    I had a lot of rear rotor wear with the OE Rear pads. None I can see using Carbon Loraine. BUT the CL pads on the front make a whirring noise, that other pads do not. So not using them again on the front. Not taking chances on the rear, the rotor is at 4.6MM and I do not want more wear.
    Rod
    No personal experience, but I read reviews of the EBC sintered with beemers which reported problems with the sintered pads kicking in the abs too soon.
    Based on that I just ordered some EBC FA407 pads on amazon. Those are not the pads you'd recommend then? (Organic, kevlar I think).
    2000 r1100rt
    Mar 2010
    Quote Originally Posted by 22893 View Post
    2000 r1100rt
    The HH pads are sintered and stop more aggressively. I use them on the twin front rotors. On the back I use the OEM organic pads or the EBC equivalent as they are a bit softer and easier on the rear rotor which is really a bit small for the app I think. Pads are cheaper than rotors is my thinking here and also most of your hard braking should be done on the front anyway. Use the rear to "set up" the bike for stopping and it helps keep the nose up if you hit the rear first but then transition to the front which is where I get on them a bit harder.
    Apr 2016
    Roswell, GA
    '99 R1100S ABS brake pads
    BE SURE you are ordering TWO SETS of pads, left and right for the front. Don't ask me...
    Amazon had them cheaper and got them here quicker:
    EBC Brakes FA363HH Disc Brake Pad Set
    Sold by: Amazon.com LLC
    $28.05
    Feb 2005
    Trinity, NC
    Quote Originally Posted by lowndes View Post
    $28.05
    EBC FA363 Brake Pads are the rear pads - only one set needed.
    Front pads are EBC FA407 or FA246 - two sets needed.
    Michael Stock, Trinity, NC
    R1100RT, R100, R60/6
    Apr 2006
    The carbon Loraine pads sold by beemer boneyard very good too.
    2010 F800GS Full Ohlins package, '04 R1100S Replika
    '01 F650GS Wife's bike
    Maritime Alps and Vosges 2012
    Tuscany and Central Italy 2010
