kentuvman
Once upon a time, I test rode a K1200GT at the Gillette WY in 2008 rally and loved it. Bought a 1987 K75s instead and have owned it for the past 8 years and have put @30k on her. She's a great ride and wish BMW would make a new and improved K75 but not holding my breath. The only reservation is this bike is @ 100# heavier than what I currently ride.
The bike for sale has @32,000 miles. Asking price @$7k - understand there were some issues with cam chain gear and don't think this issue was addressed. Just wondering what I need to be aware of. If it's made anywhere close to my K75s I'd think it's made pretty bulletproof.
Thanks,
Ken
PS - read a thread on this forum shown below - @ how much would a dealer charge to perform upgrade to camchain tensioner and jump guard? How easy to DIY?
The camchain tensioner and jump guard are a needed upgrade and most likely done. The tensioner is located on top of the block above the clutch cover. The original is a flat plate with a clamp for the hyd line. The new tensioner is a raised tube. ..visible on a S model, not so much on a GT right behind right side fairing
Replaced the timing chain,rails and sprockets on the higher mileage bike because the tensioner upgrade did not silence the marbles in the valve train at start up scary noise...BMW now recommends changing at 30K I recall anways.
I also changed all cooling hoses, 3 I think, on this bike because of age and I had all parts off doing the timing chain and valve check...the valve check is tedious but after doing about 6 bikes have yet to find any out of tolerance..it takes shims to adjust as wella
The airbox on the S has dual snorkels and two air elements..the GT has one. If it doesn' t idle goofy and stall a lot you are prob ok on airbox. The new box has a larger idle control valve/ PCV(seperate part) that was an issue. You have to change box and valve if needed. Have dealt with a few GT's with airbox, our S's have not had the issue. Was time challenged to find pics and prior thread this morning.
Thanks,
Ken
