Results 1 to 15 of 18
Thread: Stranded with coolant leak
    Hi Guys and Gals...
    Sorry my first post has to be for help.
    I am in Colorado Springs competing in a rally and need some advice.
    My bike fell over on the right side. Was on the side of the highway picking my glove which I dropped. Ground was not level and bike tipped over on the right side.
    Got some help from a good samaritan passerby and got it upright. Bike started up so I took off. 5-10 miles down the road I had the red triangle of death flashing and coolant was coming out at a low to moderate rate on the right side. Temperature indicator was pegged. Fan was running too. I let it cool down and got another few miles down the road before it was maxed out again hot.
    I called BMW roadside service and they got me a tow to Colorado Springs and now I am waiting until Tuesday and the BMW dealership opens.
    I am assuming the weight of the bike on the running light end up putting pressure on the radiator or hose and made a leak.
    1. Any ideas of what might have broke that caused the leak? I haven't had the fairing off so not sure what all is in there.
    2. Any suggestions on how to get a quick fix so I can get back on the road? I have the tools to get the fairing off. Bike is under warranty so I don't want to do anything to void that. But desperate to get riding again.
    3. Any other suggestions for rental bikes or loaners? I have to be on a bike to compete in this rally.
    Thanks,
    Barry
    317-999-7893
    Registered User BMARC153920's Avatar
    Dec 2014
    Orange County, NY
    Right side could be the water pump. It's exposed. I'd check that first.
    Not the water pump.
    What happens when the bike overheats? Where would the overflow be if it boils over?
    I know the coolant reserve is in the front but couldn't find the overflow hose. Not sure why the bike would overheat unless I lost coolant pressure?
    Administrator 20774's Avatar
    Welcome...sorry you're having troubles. Have you checked the Anonymous Book? Do you have your paper copy with you? If not, try this electronic version:
    http://www.bmwmoa.org/?abook
    Mansfield,MA
    When the bike went over, did you see coolant on the ground? How much- a real guess? Was the bike running? Some of these "newer" engines can get "air-bound" when they take a "nap" or get turned upside down.
    Tough way to make it to the forum, welcome!
    Gary
    Mod Squad
    2009 F800GS 1994 TW200
    Quote Originally Posted by BMARC153920 View Post
    Ive been MOA member for years. I lurk on here occasionally. Mostly post on Facebook but Rally rules prevent me from accessing facebook while rally in progress.
    Bike was not running when it fell over. And no coolant was present (that I noticed) where it fell over.
    I have my anonymous book with me and considered making some calls. But got busy this morning working on one of my GPS (Nav 5) which is really screwed up and not routing properly. Trying to do the update and it keeps failing....Arrrgg. I have a Zumo 665 also but really need both.
    Once I get the Nav5 working I think I will start calling around. Even 12 hours earlier on the road makes a huge difference in point scoring.
    I ride with DOG 2bikers1collie's Avatar
    May 2014
    Cape Cod, MA, USA
    Head over to k1600forum.com and as the gurus there. There are reports of bike being 'totaled' by the insurance companies when they fall over without engine bars. The blocks are aluminum and exposed to damage without them unfortunately.
    Jess & Christine, the Chauffeurs, for Tobi & Skye the Border Collies.
    2013 K1600 GTL in Damask Red with a few Farkles and a home-made trailer (the boys' ride)
    2016 S1000XR in Racing Red (The girl's ride)
    Debbie's Servant Lee's Avatar
    May 2003
    SW Iowa
    Quote Originally Posted by beairmo View Post
    Let us know what the shop finds today. Hopefully it's air in the cooling system and will be easy for the shop to fix.
    Good luck on completing your rally.
    Lee
    2016 R1200RS
    MOA # 30878
    Not so lucky as to it being something simple like air in the system.
    Since I don't have engine crash bars, the weight of the bike rested on the flood light which pushed in on the outside of the radiator. This made a very small hole in the plastic and caused the leak.
    Had to pay expedite fee but new radiator should arrive this morning and I will be back on the road. Total bust for the rally I am in but I learned a few things for next time.
    A big shout out to Pikes Peak Motorsports BMW in Colorado Springs. They are taking really good care of me getting the bike in and figuring this out.
    Anyone got a set of engine guards they want to sell and live between Denver and Reno? I will be high tailing it to Reno this afternoon. If this were to happen again I would be very unhappy. Cost of repair is over $1300 not including the cosmetic damage to fairing and flood light.
    May 2003
    SW Iowa
    Ouch Not cheap, but cheaper than a engine case.
    Thanks for the update.
    Lee
    2016 R1200RS
    MOA # 30878
    These bikes should come with engine guards as standard equipment
    When I removed the fairing for mounting engine guards, I could see the potential hazard. Fog light mount is directly in line with side of radiator. This is not a freak accident but a design flaw. Your misfortune should be warning for anyone riding this bike w/o engine guards. Hope you have a better ride on the way home.
    Quote Originally Posted by Doc_Shaw View Post
    Got the bike back yesterday afternoon and high-tailed it home with tail between my legs. Since I didn't make it to Reno, I couldn't score any bonuses and not enough time to get to Reno and Back. I will try again at another rally.
    Just in case somebody reads this who is on the fence about getting engine guards.... Don't wait! The hole in my radiator is huge and the bike just barely fell over. Here is a pic.
    Nov 2011
    Central Ohio
    That just reminded me to add some JB Weld to my toolkit. Thanks!
    Larry
    2006 R1200RT
    Mansfield,MA
    In a pinch, I have used a rubber washer, steel washer and a properly installed self-tapping screw to stop a leak like that........And get me back going.
    Mod Squad
    I considered that. But I was heading into the Phoenix and then Death Valley and knew it was going to be super hot. But definitely need to add radiator repair kit to my onboard supplies. If it would have happened on a weekday and not a holiday weekend, I would have salvaged the rally. But lost 4+ days on this one with it happening on Sunday morning before the 4th.
