Results 1 to 15 of 28
Thread: TPMS sensors
    TPMS sensors
    I am getting my TPMS sensors replaced but am wondering if the technicians need the whole bike or can this be done with just the wheels and tires, in other words without the bike. Do they need to sync them with the bike's computer or is this automatic and no software or link up is require? If the latter, I will wait to do the front and get a few more klicks out of that tire.
    KevinRT
    Ottawa, Canada
    Debbie's Servant Lee's Avatar
    May 2003
    SW Iowa
    You need to sync them to your bike.
    It can be done with a GS911.
    Lee
    2016 R1200RS
    MOA # 30878
    Thanks, that's what I thought. Two new tires then! Going to be an expensive day.
    KevinRT
    Ottawa, Canada
    May 2003
    SW Iowa
    Out of curiousity, how long did your TPMs last?
    Lee
    2016 R1200RS
    MOA # 30878
    I need mine replaced too. The cost is ridiculous $475.50 installed. Batteries lasted 7 Years 3 months.
    "The Older I Get, the Faster I Was"
    '09 Black Metallic Sapphire "Fully Farkled" RT
    Registered User Dann's Avatar
    Dec 2013
    Laval, QC, Canada
    Quote Originally Posted by Atomicman52 View Post
    Ouch! That makes pretty expensive batteries....
    Mine didn't come with TPMS and a retrofit would have costed something like $800 in parts only.
    I installed a 3rd party TPMS and the wheel sensors use calculator batteries that I can replace myself for less than $5 each
    Daniel
    If you can park it, and not turn around to admire it before walking away, you bought the wrong one.
    R1200RT 2007 - IBA # 56396
    Schmails
    Jun 2015
    Outside Philly, PA
    How many miles did they last? I was wondering if battery usage is more tied to the transmitting of data for each mile run.
    Thanks --Chris
    Greetings from the Philadelphia Suburbs.
    '11 R1200RT Bronze
    Registered User BMW_Ken's Avatar
    Nov 2004
    Kingsport, TN
    Quote Originally Posted by Dann View Post
    Which system did you go with?
    Ken Martin
    2011 R1200RT
    Kingsport, TN
    Rocky Bow BMW Riders #197 bogthebasher's Avatar
    Apr 2008
    Calgary AB
    I think many of us who own motorcycles that are aging are about to get quite a shock when we have to replace these tire pressure sensor parts. I did a quick search from the official BMW parts source in Canada http://www.parts.bmwbikes.ca quoted the following prices - admittedly the 'sticker/sign' probably is not necessary but the total cost without installation would be $463.75 CAD.
    RDC sensor for front wheel
    1. Sensor. RDC 36318532732 $235.00 CAD
    2. Pin. RDC 36238521833 $11.75 CAD
    3. sign "TPC" tire pressure control 71217698971 $4.50 CAD
    RDC sensor for rear wheel
    1. Sensor with valve. RDC 36318532731 $185.00 CAD
    2. Repair kit, tire pressure monitor valve. RDC 36318520871 $23.00 CAD
    No mention of the CR2032 (lithium) battery because it is soldered/welded inside the sensor. Also not sure how difficult it would be to perform the change oneself.
    Ken Dittrick
    2008 R1200RT (Biarritz Blau)
    Excuses are the rocks upon which our dreams are crushed - Tim Fargo
    Schmails
    Jun 2015
    Outside Philly, PA
    Quote Originally Posted by bogthebasher View Post
    I think many of us who own motorcycles that are aging are about to get quite a shock when we have to replace these tire pressure sensor parts. I did a quick search from the official BMW parts source in Canada http://www.parts.bmwbikes.ca quoted the following prices - admittedly the 'sticker/sign' probably is not necessary but the total cost without installation would be $463.75:
    No mention of the battery but perhaps it is included with the sensor? Also not sure how difficult it would be to perform the change oneself.
    This guy shows how to replace the batteries... But it's quite a task.
    https://m.youtube.com/watch?v=Mpjz0cDjnK4
    I think I would just buy replacements when the time comes....
    --Chris
    '11 R1200RT Bronze
    Apr 2008
    Calgary AB
    Quote Originally Posted by schmails View Post
    --Chris
    Yes agree, i just saw the video and looking at the comments after one should get batteries that have a welded tab since soldering directly to a battery not easy or reliable.
    Ken Dittrick
    Albuquerque, NM
    The sensors "live" in a really harsh environment, subject to lots of shock and vibration and temperature extremes. I'd think battery life and life of the rest of the components is pretty similar ... making battery replacement alone not worth the effort. Once again, neither BMW nor anyone else is trying to "screw" you with high prices. This is the cost of doing business---divide by 7 for cost per year.
    Kent Christensen
    21482
    Dec 2013
    Laval, QC, Canada
    Quote Originally Posted by BMW_Ken View Post
    I'm using the Steelmate TP-90
    Daniel
    Dec 2013
    Laval, QC, Canada
    Cost of my system divided by 7 comes up to $1.47 / Year vs the OEM at $66.75/ year.
    I think that BMW has a big interest in not making the batteries serviceable.
    Even changing the entire system (Monitor + 2 sensors) would only come up to $17/ year
    Like I said before, these are very expensive batteries.
    Daniel
    Nov 2004
    Kingsport, TN
    Does your front wheel have the valve stem coming out the side of the wheel? I have heard that some of the sensors that scre on the valve stem will interfere with the brake caliper on the front wheel.
    Ken Martin
    2011 R1200RT
    Kingsport, TN
