Results 1 to 6 of 6
Thread: 2015 RnineT Vololight Installation Assistance
    Sep 2009
    Chestnut Hill, MA
    A friend with an RnineT purchased Vololights for his ride. He attempted the install, but after riding with him on Sunday and attempting to calibrate the lights, it appears that there's a problem. I tend to think that somehow he tapped into the CanBUS system on the bike for a source of power. I believe that the RnineT has a system which is partially CanBUS and partially conventional in order to make customization easier.
    The symptoms are: 1) that the LEDs in the Vololight piece are not very bright when they light up at all, 2) the system seems to calibrate successfully with the appropriate number of flashes, but 3) there's no LED activation upon slowing down.
    Any help or advice anyone could offer is sincerely appreciated.
    John Gamel
    2015 Ebony Metallic R1200RT
    BMW CCA 2006 - Present; BMW MOA 2009-Present
    Walt Kelly: "We have met the enemy, and he is us."
    rabid reader dbrick's Avatar
    Santa Cruz CA
    Hi John,
    I have no experience with Vololights.
    I'd disconnect whatever power connection he made, and then temporarily reconnect the power feed directly to the battery. That way, you can see how the lights behave when the feed is not being affected by a Can-Bus issue. If the lights work correctly with a direct feed, then you know that the prior feed is an issue. If they behave the same, then I'd suspect the lights are defective.
    David Brick
    Santa Cruz CA
    2007 R1200R
    Registered User wyman.winn's Avatar
    Jul 2013
    Solvang, CA
    er, ummm...might want to call VoloLights....just sayin...
    ~wyman~
    2015 S1000R - Duke - Black Storm Metallic
    2013 R1200RT - Sassy - Fluid Grey Metallic
    Sep 2009
    Chestnut Hill, MA
    Thanks Dave and Wyman. He was going to call them yesterday, but hadn't heard back yet. I figured someone had done this and had the key to the problem.
    John Gamel
    Nice hat Wyman !
    Jul 2013
    Solvang, CA
    Quote Originally Posted by rdubarton View Post
    Nice hat Wyman !
    thanks....
    ~wyman~
