Results 1 to 5 of 5
Thread: charging system 77 r 100
    Registered User TIMRFO's Avatar
    Jul 2004
    southwestern Mi
    I need to replace my alternator and was wondering what was the best way to go. I wanted to update it so I could use my electric gear. Tim
    Administrator 20774's Avatar
    Here's a couple of websites to review:
    - Snowbum's site...lots to pour over: http://bmwmotorcycletech.info/AftrMrktAlt.htm
    - Anton's site...aftermarket systems at the bottom: http://www.largiader.com/articles/charging/
    If cost is not an impediment to upgrading your charging system you could increase from 240 W (stock) to around 450 W with the Enduralast system or 600 W with the Omega system. The Omega system is from Rick Jones at MotorRad Elektrik (600 W must be new as I recall the prior offering being around 450 W) for $600. The Enduralast system is $500 from Euro MotoElectrics. Both systems seem to have a good reputation as do the vendors selling these units. I know folks with both (older 450 W Omega) and have had positive experiences.
    Personally, I would purchase either with no qualms. EME appears to offer some less expensive options that provide lesser (but still more than stock) output - I have no knowledge about these systems.
    Links for both follow -
    http://www.motoelekt.com/charging.htm
    http://www.euromotoelectrics.com/pro...450-altkit.htm
    http://www.euromotoelectrics.com/EnD...stems-s/22.htm
    Another option that is like an upgrade to the charging system, use LED lights for the headlight and running lights. I have done this and find the higher light output quite beneficial and demand less from the charging system. Replacement H4 bulbs and various LED running lights can be had from AdvMonster or SuperBrightLEDS. Links follow -
    http://stores.advmonster.com/h4-led-headlight/
    http://stores.advmonster.com/h4-r3-led-headlight/
    http://stores.advmonster.com/led-lights/
    https://www.superbrightleds.com/more...aid/2221/4993/
    https://www.superbrightleds.com/cat/...iliary-lights/
    Beemerphan Radar41's Avatar
    May 2003
    Longmont, CO
    Cool Electrical system upgrade
    I installed the 600 watt system from Ted Porter (same system Rick has, so either supplier is good) on my R100RS about a month ago.
    SO far give it HIGH marks, easy to install, output is GREAT. With heated vest (bmw), heated grips, additional running lights (LED) and the headlight on bright, the Voltage is stable at 14.5 VDC.
    If you want to run heated gear and aux lighting, go for it!!
    Don "Radar" Wreyford
    00 K1200LT, 98 R1100GS AE, 84 R100RS, 76 R75/6
    MOA # 91738, RA #27032 , ABC #7915 - "Insanity is doing the same thing over and over again, but expecting different results" - Albert Einstein
    Jul 2004
    southwestern Mi
    Quote Originally Posted by TIMRFO View Post
    Thanks for all in the good info..Tim
