Results 1 to 11 of 11
Thread: AeroStich Tank Panniers
    I have a question regarding using the AeroStich tank panniers on my 2014 G650GS single. Will they cause me any cooling problems due to where they rest on the faux tank? I have always wanted to try them, as they are a really functional piece of luggage, but have been told (always by someone who has never owned a G650GS) that they "might" cause an air intake problem. I am not looking for opinions on tank panniers, soft luggage, blah, blah, blah...only knowledgeable comments on my question. I would really like to hear from P.Glaves on this. Thanks in advance....Gail
    Gail Thorne
    2014 G650GS
    Quote Originally Posted by shortythorne View Post
    You my dear are in luck. I have used Aerostich tank panniers on my F650 single a number of times to no ill effect. There is plenty of room for air to flow downward after the radiator - cooling works just fine. You might feel a little warmth on you calves but I never noticed it as an issue. They absolutely won't block intake air to the engine either.
    BTW, Happy New Year!
    You my Dear, ARE THE MAN! I knew you would know, I just knew it!!! Thanks so much for your quick reply, and Happy New Year to you & Voni. Thanks...Gail
    Gail Thorne
    2014 G650GS
    Fissah! AKThumper's Avatar
    Apr 2008
    Canyon Creek, MT
    Hey there! I have used them on both the 650 thumper and the 650 twin. NO problems whatsoever. One side I fill with misc items like tire pressure gauge, cloth for wiping face shield (soaked in water, wrung out, and stuffed in a ziplock), and chain lube. Other side has drinking water bottles and stuff i cannot cram into my tank bag and need to access quickly. By wrapping a bungie around through the back slots I can also hook them to the crash bars, and the front bar as well which prevents any moving around. I was worried about them scratching my tank, so I found some seat belt comfort straps at Walmart, with velcro backs, cut them to fit and stuck them on the straps to prevent any rubbing.
    Worked out perfectly!
    F650 GS 2007, F650GS 2011,F800GS 2014
    Team Pterodactyl, Dessert Division
    A Bit Wester of HQ
    I've got about 10k on mine and leave them on the bike year round. One side holds my tools and misc bike stuff and the other side holds my compressor, water bottle and lunch for commuting. They also block the wind rather nicely in cool weather.
    Panniers Good to Go
    Like the others here, I've had no problems with the Aerostich panniers. They hold a lot of stuff in a good location, and can also make a nice lower fairing to keep the cold off your upper legs when the temps get chill. I did add helicopter tape to all the places on the "tank" where they might chafe the paint. That was 8 years ago. I just pulled up some of the tape, and the paint still looks like new.
    Registered User jek_ict's Avatar
    Aug 2015
    Wichita, KS
    Pictures of Installed Panniers?
    Anyone have pictures of the panniers installed on their F650? I just picked up a used pair of the panniers to use on my '03 F650GS. When I throw them over the "tank" the panniers are in the way of my knees, even when the leading strap is pushed all the way to the handlebars.
    I tried putting the leading strap forward of the handlebars and the panniers clear my knees. But, I'm concerned that they might interfere with handling and they block the side air inlets.
    ~Jason
    Turn your head sideways...... these are the "competition" sized panniers.
    A more conventional view.
    You can see that there is plenty of room for hot air to escape, although on hot days you can feel the warmth more when these are in place.
    I think my panniers are 20+ years old and work great. I use them mainly to carry heavy, less-frequently-used items like tools. Positioning dead weight like this close to the bike's center of mass greatly improves handling compared to locating the stuff way out back.
    Ian
    Go soothingly through the grease mud, as there lurks the skid demon.
    __________________________________________________ ________________________________
    '67 Trail 90 || '86 R80 G/SPD+ || '97 F650ST || '00 1150 GS || '06 HP2e || '07 Xchallenge || '14 Grom
    Aug 2015
    Wichita, KS
    Thanks. I think I have the full size panniers. I'll try to fiddle with them some more tonight and report back.
    ~Jason
    May 2012
    DeSoto MO
    Quote Originally Posted by Visian View Post
    Ian
    I see you have the Mosko soft side bags. I've got them too, and love the flexibility that they provide for touring.... also don't worry much about dumping anymore as far as damage...
    I like being able to remove them, in the rain, with the turn of a key.
    They also take drops very well.
    Sent from my HTC One_M8 using Tapatalk
