Results 1 to 6 of 6
Thread: Broken bulb spring retainer?
    Jul 2014
    Eastern Washington
    Has anyone else had the little tabs that hold the bulb retainer spring break? On my 07GSA the little tabs that hold the pivot side of the retainer spring were broken when I opened it up to replace the bulb. Looking more closely at them, and on the intact high beam spring, they seem to be made of a pot metal type material.
    I was able to slightly modify the spring and retain it under the small Phillips head screw on the pivot side. During previous bulb changes I always thought it was a sort of hinkey system for retaining the bulb. It looks like to replace the pot metal tabs would mean buying a whole new inner assembly. Glad there was a good workaround.
    Registered User Woodbutcher's Avatar
    May 2010
    Austin, TX
    Rusty
    Austin, TX
    Two Wheeled Texans
    2009 R1200GSA
    Jul 2014
    Eastern Washington
    Quote Originally Posted by Woodbutcher View Post
    Thanks for posting that! Different than the way I fixed the problem but a great solution. After looking at the little nubs I figured I couldn't be the first one this happened to n
    Registered User talmadge_w's Avatar
    May 2008
    Houston, TX
    Just posted a fix to this under the spring clip thread in Motorad. Moderator may want to move it over here?
    Talmadge Wright
    '12 R1200 GSA
    '14 R nine T
    Mansfield,MA
    Quote Originally Posted by talmadge_w View Post
    I'll look it over a bit later and add both threads to the Tag Cloud for future reference
    Mod Squad
    2009 F800GS 1994 TW200
    OLD BULL
    Sep 2007
    Livonia MI
    Beemer Boneyard
    I just order some other stuff from the Boneyard and saw they have premade clips for H7bulbs for $17 each. Another option.
