Results 1 to 15 of 18
Thread: 2013 rt1200
    Dec 2010
    Central Ma.
    2013 rt1200
    I found a 2013RT w/9100 miles at a Indian dealership. They don't know anything about the bike as far as what options it has. I was able to determine it has the radio and it has the multi-controller wheel on the left handgrip. $14,000.0 and the bike has many other farkles like the rider backrest, akropovic pipe, small driving lights on the front forks, Givi trunk, valve cover guards and chrome saddlebag crash bars. Any thing I need to look for? I was able to putt around the parking lot because I didn't have my riding gear and the front end seems like it pulls to one side. Max's BMW in CT. sold the bike and did the 600 mi. checkup and the bike is warrantied until Feb., 2016. I currently ride a 2000 RT1100.
    Registered User Emoto's Avatar
    Jul 2003
    Boston
    Quote Originally Posted by rwl1955 View Post
    Take it to a BMW dealer and have them check it out for you. Also, they should be able to plug in the VIN and tell you everything about the options and configuration.
    Eventual Master of the Obvious
    SE Mass - SOHC4 - DoD - BMWMOA - EMOTO #1
    ...proud walking jingle in the midnight sun...
    Free Smugmug Discount Coupon: mStnWv71mNkjo
    Dec 2010
    Central Ma.
    Quote Originally Posted by Emoto View Post
    *******The Indian dealer called Max's to verify the bike was bought there. If I buy the bike that will be my first task.
    Dec 2010
    Central Ma.
    Peg Lowering Kit
    I bought the 2013RT and I need to lower the footpegs. Anyone recommend a specific company/brand?
    Mar 2010
    Vancouver, B.C. Canada
    Try googling suburban machinery. I think they make them for your bike.
    You should have better luck getting answers on your 1200 over in the Hexheads forum. This one is for oilheads.
    Mansfield,MA
    Sending it on over
    Mod Squad
    2009 F800GS 1994 TW200
    Registered User pacsman's Avatar
    Jan 2011
    NE Ohio
    i will vouch for the suburban peg loweres. I have them on my 2011 RT and my wife has them on her 2014 RT. They are great company with fantastic products.
    Dec 2010
    Central Ma.
    Thumbs up Peg Lowers
    Quote Originally Posted by pacsman View Post
    Thanks for the recommendation. I had the lowering kit on my 2000RT and Suburban looks like they make a good product. WOW! What a difference from my 2000RT to this 2013RT. I only wish the original owner had ordered the ASC. The bike has the ESAII and the audio system. Did you have to replace the shifter?
    Jan 2011
    NE Ohio
    Nope.
    Albuquerque, NM
    ASC is easily retrofitted by your dealer.
    Kent Christensen
    21482
    Dec 2010
    Central Ma.
    Thumbs up Asc
    Thanks for that tip. I was going to ask Max's if that was possible. The bike is under warranty until 2/2016 so I'll put it in for the 12,000mi before the winter
    Dec 2010
    Central Ma.
    Oil Consumption?
    The oil in the sight glass was half way when I picked up the bike. 500mi. later and no oil shows in the sight glass. Is this because the motor is still breaking in? Max's said to use semi-synthetic oil 15W-50. Is this just for break in? What are you guys running for oil, full synthetic or semi-synthetic? Should I use full synthetic after break in?
    Registered User wyman.winn's Avatar
    Jul 2013
    Solvang, CA
    i used BMW branded semi-syn 15w50 for the first 42000 miles, now i use Mobil 1, 15w50....my 2013 used a bit of oil during the first 36000 miles and now that it is over 57000 i find it only uses a bit of oil if i keep her "on the pipe" riding at and about 5000rpm....~4000rpm and below she uses virtually zero oil....
    just my 2 worth....
    btw, i change oil/filter GB & FD every 6000 miles....
    ~wyman~
    2015 S1000R - Duke - Black Storm Metallic
    2013 R1200RT - Sassy - Fluid Grey Metallic
    Dec 2010
    Central Ma.
    Question Oil
    Quote Originally Posted by wyman.winn View Post
    just my 2 worth....
    Max's wants $14.00 a qt. for their oil which is a ripoff. My question is when should I switch to full synthetic? I'll have the 12,000mi. done and let then change the oil but after that I'm not paying $110.0 for an oil change.
    Jul 2013
    Solvang, CA
    i would keep a very close eye on the oil required between changes and let that be your guide...i measure the oil in and keep a log of what i add between changes....my RT "stopped" using oil at about 24000 miles, yours may vary....now, i only add about 5-6 oz total in 6000 miles....
    wyman
    ~wyman~
