Results 1 to 3 of 3
Thread: "Registered User" needs replacement
    jimcameron
    When I post, right under my name and above my IBMWR avatar, it says "Registered User", all the other cool people have personal quotes. I would like to replace my "Registered User" with a clever phrase.
    My fist problem is that I'm not clever enough to figure out how the replace the "registered user", please help a mean old guy that is trying to be both cool and clever. How the heck to I do change that? Thanks.
    Still Wondering mika's Avatar
    Aug 2004
    Fly Over Land
    I am not a technical writer nor do I play one on TV, but I think this should get the job done or at least point you in the right direction.
    Click on - User CP ΤΗτ it is on the tool bar that tells you where you are in the forum.
    This takes you to the control panel.
    On the left side in Control Panel, Settings & Options click on Edit Profile. This takes you to the Edit Profile: _____ panel.
    Got the second section titled: Optional Information ΤΗτ All information will be viewed by other forum members.
    The first optional field is: Custom User Title
    This is where you can enter what you want to show under your user name.
    Once you have entered what you want scroll to the bottom of the page and click on: Save Changes
    Good luck!
    Pass the mustard and UP THE REVOLUTION!
    St. Paul Pioneer Press , Minneapolis Star Tribune
    jimcameron
    It Worked!!
    I think it worked, Thanks,
