Results 1 to 4 of 4
Thread: Neutral Switch Replacement
    Nov 2013
    Delaware
    I lost my gear and neutral switch indication after a transmission / clutch project on my K1. I have verified that the switch is bad. What is the process for removing the swing arm? do I need to pull the rear first or can I pull the swing arm / drive shaft as an assembly?
    #13338 PGlaves's Avatar
    Oct 2003
    "Big Bend" TX
    Quote Originally Posted by 35164 View Post
    You can pull it all together. But, It is both heavy and weight biased to the right. Two people makes it easy. With one it is a bit tricky.
    3 Red Bricks
    Jan 2007
    Pleasanton, Ca.
    On the Paralever bikes, isn't there going to be a driveshaft timing issue when you try to put it back together if you pulled it apart in one piece?
    LONG MAY YOUR BRICK FLY!
    Lee Fulton Forum Moderator
    3 Marakesh Red K75Ss
    Mine, Hers, Spare
    Oct 2003
    "Big Bend" TX
    On the Paralever bikes, isn't there going to be a driveshaft timing issue when you try to put it back together ifyou pulled it apart in one piece?
    Yes - I forgot that detail. Actually I'm not sure it is possible to re-engage the driveshaft once pulled apart.
