Results 1 to 7 of 7
Thread: Synthetic Oil Smell
    Dec 2014
    Alabama
    Synthetic Oil Smell
    Since synthetic gear oil is man made, why does it smell just like dino, it looks like that if it is man made they could make it smell a little better.
    #13338 PGlaves's Avatar
    Oct 2003
    "Big Bend" TX
    Quote Originally Posted by kskraye View Post
    Since synthetic gear oil is man made, why does it smell just like dino, it looks like that if it is man made they they could make it smell a little better.
    It can be dino molecules modestly rearranged and still be called synthetic. Also, Coke is clear until they add the coloring because people expect Coke to be dark. And people expect gear oil to smell.
    Mar 2013
    Winnipeg, MB, Canada
    Sulfur or is it Sulphur...................Calcium Sulfanate(?) is a common additive in gear oils.
    1986 K75S(the beutch), 1993 K1100RS (blown engine), 1997 Chev Short Box (4x4 with an LT1)
    "You can easily judge the character of a man by how he treats those who can do nothing for him."
    Albuquerque, NM
    The smell of gear oil is artificially added to discourage you from putting it in your motor.
    In addition, although the viscosity is basically the same as motor oil, the viscocity numbering system for gear oil is deliberately different, again to discourage you from putting it in your motor.
    Kent Christensen
    21482
    na1g
    May 2011
    Greater Bahstin, Massachusetts
    Castor bean oil smells best.
    p
    Jul 2008
    Central PA
    20/50 motor oil is the same viscosity as 80/90 gear lube? Or, are BMW bikes using ATF like their cars?
    Cave contents: 99 R11RS, 2013 Toyota Tacoma, 03 Simplicity Legacy, 97 Stihl FS75, Dewalt DW625 & DW744
    Albuquerque, NM
    Quote Originally Posted by 36654 View Post
    Pretty much. There was a BMW car manual transmission in the 1970s that used 20W-50 motor oil.
    Kent Christensen
    21482
