Page 2 of 2 FirstFirst 1 2
Results 16 to 17 of 17
Thread: Heated Grips Recommendations
  1. #16
    Has the GS-Lust The_Veg's Avatar
    Sep 2003
    Atlanta 'burbs
    That DualStar kit actually looks like what I have...see my previous post...
    Also one thing that concerns me is the wire flexing repeatedly over time as the throttle is twisted (I think that the weakening caused by this is why my grips don't heat evenly). How does the factory setup deal with this?
    2012 R1200GS
    "If you can't fix it with a hammer, it's electrical." -somebody's dad
  2. #17
    Registered User ALIENHITCHHIKER's Avatar
    Oct 2004
    Asheville, NC
    Veg, here's a thought:
    The clutch side grip mounts on metal, the throttle side mounts on plastic - so - the clutch side looses alot of heat as the bar dissipates it. The stick on electrodes I installed included a resistor which I put in line to the throttle side so it doesn't generate as much heat, which in turn seems to even things up a bit.
    Your right though about that flex. Eventually the throttle side is going to fail.
    Steve
