Results 1 to 13 of 13
Thread: Oil Leak 2013 R1200RT
    Dec 2005
    East Texas
    Discovered an oil leak/seep on the bottom of the right hand cylinder cover this afternoon. Not a big leak, just enough to make a mess. I suspect either the cylinder head cover gasket or the gasket that fits around the spark plug. I have 26K miles on the bike and had the 24K service done a couple of months ago. When I called the dealer service manager to discuss, he indicated that the dealership had received a "batch" of bad spark plug gaskets and he suspected that was the problem. Advised me to bring the bike in and have them fix it.
    Has anyone else had a similar problem in the recent past that turned out to be a bad spark plug gasket?
    R/Jim
    Registered User wyman.winn's Avatar
    Jul 2013
    Solvang, CA
    Quote Originally Posted by Chicota View Post
    R/Jim
    not with my 2013 RT...she has 45000+ miles and has had the spark plugs out every 6000 miles when i do the service....if it is the plug gasket, there will be an oil trail down inside the coil wiring cover....have a looksee...
    wyman
    ~wyman~
    2015 S1000R - Duke - Black Storm Metallic
    2013 R1200RT - Sassy - Fluid Grey Metallic
    Dec 2011
    Menlo Park, CA
    R/Jim
    Huh? A spark plug gasket causing an oil leak? The spark plug gasket seals compression between the plug body and the head. There's no oil associated with it. And that gasket comes pre-installed on the new plug, there's no "bad batch" possible. This sounds like you're being shoveled a bunch of bovine feces.
    Maybe he means the rubber grommet that goes between the valve cover and the head. That rubber grommet surrounds the plug. If the mechanic wasn't careful when reinstalling the cover, that could have gotten tweaked. As Wyman suggests, pull your plastic plug cover off to see if there's oil coming out that way, that would pinpoint that. But not spark plug gasket!
    But by all means, take it in and let the dealer correct it. He's the last one that worked on it.
    JayJay
    '09 R1200 RT, '73 R75/5 Toaster (under rehabilitation)
    Lots of rice burners in the past ...
    Jul 2013
    Solvang, CA
    Quote Originally Posted by jayjay View Post
    JayJay
    sorry JayJay...was thinking grommet and typing gasket.....
    ~wyman~
    Dec 2011
    Menlo Park, CA
    Quote Originally Posted by wyman.winn View Post
    No, I think the dealer was being imprecise with his language. The fiche calls that thing "interior gasket", and in hindsight, I think I mischaracterized it - a gasket goes between two sealing surfaces, while a grommet lines a hole. So it is in fact a gasket.
    But whatever you call it, it's not the spark plug gasket!
    JayJay
    Sep 2013
    Toronto, Canada
    same issue with my 2012
    I had the same issue. Not serious leak. Just drips on the ground. Dealer fixed it by replacing the "cam chain tensioner bracket".
    Hope that helps.
    Dec 2005
    East Texas
    Thanks for the responses. Dealer will look at it Sat.
    R/Jim
    Dec 2005
    East Texas
    Problem Resolved
    It was the inner gasket that was leaking. Service manager indicated that they had replaced several and that there was a bulletin out advising that some bad gaskets had found their way into the BMW supply system.
    Albuquerque, NM
    What's an "inner gasket?"
    Kent Christensen
    21482
    Dec 2005
    East Texas
    On the '13 RT, it's a small, round gasket that seals the area around the spark plug hole between the cylinder head cover and the cylinder head. I may be using the wrong terminology, but that's what the dealer service rep called it. It you look a parts fiche diagram showing the cylinder head and cylinder head cover, you will see it depicted as part of the "gasket kit."
    Sep 2006
    He's being Kent...it is listed as Interior Gasket...we knew what you meant. No way a factory trained tech could goober one of those up
    Steve Henson
    Mar 2011
    Lawrenceville,ga
    I am detecting a bit of sarcasm, right?
    Sep 2006
    Quote Originally Posted by ducster View Post
    maybe
    Steve Henson
