Results 1 to 4 of 4
Thread: 2004 R1150 RT-P Heated Grips Inop
    Registered User jcabiles's Avatar
    Nov 2013
    Vienna, VA
    The heated grips on my 2004 R1150 RT-P would not work today. There were working on yesterdays ride to work, but today nothing. The indicator lights on the dash do not come on. I checked the fuses and all fuses are good. What's the next area to troubleshoot?
    MOA #24991 Pauls1150's Avatar
    Apr 2008
    south of Los Angeles
    1) Verify that you get 12 volts to the fuse (#7, 4 Amps).
    2) Verify that 12 volts gets to the OTHER side of the fuse - one that "looks ok" can still be NFG.
    3) If that power is ok, that would point to a bad switch or a bad ground (brown wires from the grips).
    Nov 2013
    Vienna, VA
    Quote Originally Posted by Pauls1150 View Post
    Great. Thanks. I'll make those checks in the morning.
    RK Ryder
    London, Ontario
    When my heated grips became intermittent, I discovered that the switch was faulty. Replaced the switch and got heat again.
    Paul
    Treasurer of the Forest City Motorrad Club #159
    Knights of the Roundel #333
