Results 1 to 4 of 4
Thread: New S1000R clutch issue
    Registered User not2brite's Avatar
    Jul 2005
    Coastal Georgia
    Just got a new S1000R and have an possible clutch issue I've never had on another bike. I'm hoping it's something someone will recognize. At less than 40 miles, I noticed an intermittent momentary catch as I release the clutch lever. It feels like the cable or the clutch itself hangs up momentarily, then releases sharply. But never on the lever pull in; only on lever release. Other facts: Fraction of a second only. No noise. Happens maybe once in five pulls, and I can't tell if it's related to a particular gear. Can't duplicate it when the bike is in neutral. Shifts normally otherwise, and the quick shift assist works fine as well. I wonder if it's simply breaking in/misadjusted and will go away in a couple hundred miles. I wiill call the dealer on Tuesday, but thought I'd give this a try. Thanks.
    I wish to have no connection with any ship that does not sail fast for I intend to go in harm's way. Capt. John Paul Jones, 1778
    You might try this S1000R Forum. its pretty active with many owners of the S1000R.
    Jul 2005
    Coastal Georgia
    Excellent. Didn't know about that one. Thanks.
    Jul 2005
    Coastal Georgia
    Followup for anyone who comes upon this thread with the same question: After some research today on several other forums, I'm going with the S1000R slipper clutch as the cause of my issue. Apparently, a slipper clutch in a HP bike using a solid clutch cable (versus a hydraulic clutch) can briefly transmit a noticeable vibration up to the clutch lever as the slipper clutch operates. Doesn't happen every time. Related to how I release the clutch and the throttle position. Same issue is reported on forums from Aprilia, Ducati and KTM. So that's what I'm going with.
