Results 1 to 5 of 5
Thread: Camhead R1200 RT 2013 Rear Diff.
    trumpetman
    Feb 2013
    Houston
    Alright, I am going to do my first ever rear-diff change. From everything I have read and viewed I was expecting a torx head bolt on the top of the rear diff. Instead, I've found a large rubber insert that fits down into a hole on the top of the diff housing. So, at the risk of sounding like a nitwit, Is this all I have to remove in order to put in new oil? Also, what oil should I be using. Any help would be appreciated. Anyone with a 2013
    R1200RT ever done this job?
    Administrator 20774's Avatar
    There is a DIY section in the Hex/Camhead forum. I'm not totally familiar with the various models and final drives. Check the threads there...maybe there's something that will help.
    http://forums.forums.bmwmoa.orgdispl...Y-Tech-Library
    Cam Killer marchyman's Avatar
    Jun 2008
    SF Bay Area
    Top of the FD housing is a breather, not an oil fill hole. At least I assume you are talking about the breather. The fill plug is on the rear of the housing. You need to remove the wheel for access.
    As for what to use... BMW recommends this and now sells it in one-use bottles.
    Ignore the wethead GS in the background.
    Debbie's Servant Lee's Avatar
    May 2003
    SW Iowa
    This link has a copy of the shop manual instructions.
    http://forums.bmwmoa.org/showthread....Change-MY-2009
    Post#3 shows the correct oil to use.
    The newer final drives now call for 180cc to refill.
    Here's the location of the fill plug on a K1300. Not sure if it's the same on a 2013 R1200
    Lee 2011 K1300S
    MOA # 30878
    Past BMW Bikes, 2003 K1200RS, 1991 K75S, 1987 K75T, 1984 R100RT
    Albuquerque, NM
    No, BMW specifies this fluid and that's not the same thing as "recommends." It means use nothing else.
    Kent Christensen
    21482
