Results 1 to 3 of 3
Thread: Zumo 550 with Sena 20S BT headset??
    Registered User tmwilmotte's Avatar
    Dec 2005
    San Antonio Area (TX)
    Question Zumo 550 with Sena 20S BT headset??
    I have a Zumo 550 that works just fine. I'm thinking of transitioning from a Baehr Ultima XL (wired) headset system to a Sena 20S (BT) headset, mainly so I can communicate B2B with the guys I usually ride with (and also receive cell phone calls while on longer trips). (They have Senas.) I'm wondering if my mp3 tunes stored on my Zumo 550 will transmit via BT to a Sena headset . Does anyone have this setup (Zumo 550 with a BT headset) and can you advise me as to it's workability? Problems encountered? Like it? TIA.
    Tom Wilmotte
    2009 R1200RT
    BMWMOA, SABMWRA, IBA
    Tourmeister gr8ridn2's Avatar
    Jun 2009
    Kern Valley CA
    The problem with the music would be the 550 does not have stereo Bluetooth, A2DP. It probably won't activate the MP3 player unless it is connected to a line out source. GPS directions and mobile phone should work through the Zumo 550 to the Sena headset.
    2014 R1200 GSA W
    Riding is the art of throwing yourself at the ground and missing
    Registered User Woodbutcher's Avatar
    May 2010
    Austin, TX
    Quote Originally Posted by gr8ridn2 View Post
    Yep, you nailed it. For the OP, put the mp3 music on the phone and play it on the Sena.
    Rusty
    Austin, TX
    Two Wheeled Texans
    2009 R1200GSA
