scottishsg
Good afternoon all!! Whilst cleaning up the rear swing arm preparing to give her a little tlc, I noticed that the swing arm bearings had some play. Basically if I put my finger in the center race where the pivots would go, there is some in and out play. Looks like the bearing outer is pressed in flush with probably a flange surface so can't be pushed in further, but can be pulled out slightly. Talking fractions here.
Is this normal? Or should they be completely solid in all directions.
Thanks in advance to all you gurus!!
