Results 1 to 10 of 10
Thread: Iphone 6 Plus and my GTL?
    Drew
    Mar 2012
    Fredericksburg VA
    I love having my IPhone 4S connected to my bike. But I'm considering upgrading to the IPhone 6 Plus. I'm wondering if it will fit in the compartment on the right side of the bike. That will make a big difference in my decision.
    Cage Rattler wezul's Avatar
    Nov 2006
    Glen Ellyn, IL
    Quote Originally Posted by 177171 View Post
    Here are the dims
    Registered User okiegman's Avatar
    Feb 2012
    Eufaula, Oklahoma
    I think not
    I have a 5s which I keep in an otter box which will not fit. I took the foam insert out and the problem is the overall length when you add the adaptor from the old style (4S and previous) connector to the new style. The otter box doesn't add a whole lot to the overall length but when you add the adaptor it's a no go.
    Here was/is my solution. http://www.k1600forum.com/forum/bmw-...ount-help.html
    Scroll down to Arizona Jim's post
    I use an otter box with a slip grip mount https://slipgripcarmounts.3dcartstores.com
    Sorry for the pic - sent my daughter out to take a pic, and well.....
    Wes Fitzer-MOA BoD - President
    BMWMOA 170126
    NE Oklahoma BMW Club; BMW Riders of Oklahoma
    2014 K1600 GTLE
    Mar 2011
    socal
    My dealer advised when I got my GT to NOT put phone in right side compartment due to heat
    Have a bar bag with cable to power plug no issues..
    Cupcake greg's Avatar
    Jun 2014
    Central Valley California
    Quote Originally Posted by t6pilot View Post
    The same caution is in the '14 RT owners manual. Pretty amazing, a compartment for your electronic devices that they advise you not to use.
    I've found that if the ambient temp is below ~85 degrees it doesn't get too hot. I have cooked my iPhone in the tank bag to where it shut down. A piece of white paper in the map window fixed that issue.
    Greg
    South Central Valley, CA
    2014 R1200RTW, 2010 Yamaha TW200, 1978 R100/7
    Dec 2013
    Central Ct.
    Yes...it fits.....
    ....My wife just got the 6 (Not the 6Plus) It fits in the slot in the foam (without any sort of case etc) I suppose the foam could be "altered"if you do have a case. And....yes....if you do go this route, I suggest a meat thermometer.....so you can pull it out before it gets "Well Done".
    I personally don't use either compartment for anything that will "Melt"......It is rather piss-poor that they designed it as such......silly Germans.
    Drew
    Mar 2012
    Fredericksburg VA
    Quote Originally Posted by mrmrsnct View Post
    Thanks!!!
    Off to the apple store I go... And to Amazon for the correct connector
    i5
    never had my i5 shut down while in the foam without it's otterbox case. Been riding on some hot days this summer too.
    David S
    Sep 2014
    Durango, CO
    Status ?
    Thanks!!!
    I was wondering if the iphone6 and the connector cable you bought worked out. What connector did you purchased ?
    Thanks, David
    i5
    I use my i5 without the otterbox in the foam and have never had a shutdown and love it. I keep my garage remote in the left side case and it's never melted...and I do use premium gas... not sure where folks are riding where these compartments are a problem...or for how long. all ok here
