Results 1 to 15 of 18
Thread: Throttle body sync: Manometer requirements?
Hybrid View
    Riding Dutchman jacco's Avatar
    Mar 2005
    Kensington, MD
    Hello,
    I'd like to do my own throttle body sync so that I don't have to spend the entire Saturday at the dealer again (busy summer season). From what I read on ibmwr.org it seems fairly easy to do, all I need to get is a differential manometer. What are the requirements for such a manometer, apart from two inputs so that it can do differential? I'd like to get a digital one if they're not too expensive. What are the requirements? E.g. range, resolution. Anything else I need to know before I start on this project? A manometer is the only 'special' tool I'll need, correct?
    Thanks,
    Jacco
    Has the GS-Lust The_Veg's Avatar
    Sep 2003
    Atlanta 'burbs
    Well, you could build one from a yardstick and about 20 feet of clear plastic tubing. This will cost you about $4.
    2012 R1200GS
    "If you can't fix it with a hammer, it's electrical." -somebody's dad
    Mar 2005
    Kensington, MD
    Quote Originally Posted by The Veg
    I know. But there are cheap used manometers on eBay. I've never done a throttle body sync, that's why I'm trying to determine what kind of range/sensitivity I'll need. I don't mind investing a few (say up to 50) dollars to compensate for my lack of skill.
    Thanks anyway ,
    Jacco
    leave my monkey alone LORAZEPAM's Avatar
    West Salem, OH
    the manometers are cheaper, and easy to use, but the best too overall would be a twinmax. It is a true differential tool, and the mercury manometers use a separate tube for each TB. You have to get the tubes rising equally when balancing, and you aim for zero on the twinmax. I use the manometer for quite a while, and since I bought the twinmax, they are collecting dust now.
    Gale Smith
    2009 Versys
    1999 R1100RT
    Mar 2005
    Kensington, MD
    Quote Originally Posted by lorazepam
    Thanks lorazepam. I read about the twinmax on ibmwr.org. Costs about $100 I think? But it seems that most digital dual-input manometers are also capable of computing the differential pressure between their two inputs. I was wondering if this would be a valid alternative (new approx. $200, but less when used, for example on eBay), since I could potentially use it for something else as well. But they come in a whole spectrum of ranges/sensitivities. I don't suppose we're talking tens of PSIs here, but to be honest I have no idea, really...
    Regards,
    Jacco
    West Salem, OH
    I have seen the twinmax listed from 79.00 to around 90.00. To me it is a no brainer tool, and makes the job so easy. I cannot comment on the digital manometer units, having no experience with them, but more than one mechanic has said that the twinmax is their tool of choice for the job.
    Gale Smith
    2009 Versys
    1999 R1100RT
    Apr 2007
    Nacogdoches, TX
    Quote Originally Posted by The_Veg View Post
    +1
    What I did. Works great.
    I did cough up the extra for a yellow aluminum yardstick. Looks really cool with the red ATF.
    '08 BMW R1200RT
    '75 Red R75/6
    Aug 2006
    Scranton, Pa.
    Twinmax
    Been there, done that with homemade and mercury stiks.
    pay the shot and buy the twinmax. It will take all the guesswork out of things and your bike will run far better.
    Best,
    Will
    Nothing works better than pure physics fluidics and gravity. I did the ATF in tubing on a stick and you cannot get more accurate results IMHO
    Vancouver, B.C. Canada
    Quote Originally Posted by zoomtoob View Post
    I agree that a 2X4 with tubing filled with ATF will get the job done cheap but having tried that type of jig (bulky), mercury stix (health/environmental hazard), Twin Max (bouncy) I much prefer Grok's Harmonizer.
    I also agree that while I may not necessarily get more accurate results I think it is possible to get equally accurate results in a much smaller and convenient package that I can actually ride around the neighbourhood with to check my handiwork live and in colour with my Harmonizer on the bike.
    I can't do that with a 2X4 and twenty feet of tubing. Might be fun to try though!
    I also used the plastic tube and brake fluid after a throttle cable replacement. Started so far off it was sucking all of the fluid from one side and heading for the engine. It actually sucked a long bubble through the fluid. Improved the rough adjustment, got in range and it worked fine. What is the yardstick for? I don't need a yardstick to see level.
