Results 1 to 8 of 8
Thread: Learn Garmin BaseCamp Tutorial Videos
    That road looks good! Norwood's Avatar
    Aug 2005
    From NW AL to WNC
    During the 2014 MOA Rally BaseCamp seminar, Dan Townsley mentioned these videos for beginners. I am listing these Youtube videos for your use. The only intend is to get you over the learning curve of BaseCamp. As you will note, these are non-professional videos produced by myself with screen recorder software. Also please note while the lessons date back to late 2013, BaseCamp has updates very often and I try to add Nuggets of information to keep current.
    Using Window 8.1 - Zumo 660 -
    I hope they are helpful. I have a discussion forum with some other very versed volunteers located at: http://forums.delphiforums.com/garminbasecamp/start
    Each video can run from 2 to 15 minutes...
    Lesson 1 - The Garmin BaseCamp Map and Menu
    http://youtu.be/jDqVvHvd754
    Lesson 2 - Data storage for Garmin BaseCamp
    http://youtu.be/kpRaWRii7hE
    Lesson 3 - Edit and OPTIONS
    http://youtu.be/qwDSNPyVX-Q
    Lesson 4 - Create My Collection, your database
    http://youtu.be/stpwMUBQLNc
    Lesson 5 - The Drawing Tools
    http://youtu.be/ECNujneoot0
    Lesson 6 - Backup Database, Google Earth
    http://youtu.be/freaF_WciZk
    Lesson 7 - Find, Search, Yelp, Icons and Data
    http://youtu.be/ayGruPddSRE
    Lesson 8 - Connecting your GPS and moving data
    http://youtu.be/DZk5-wQbm84
    Lesson 9 - EXTRAS on your GPS unit
    http://youtu.be/fQmuT1tmVhM
    Lesson 10 - Routing with NEW ROUTE tool only
    http://youtu.be/1WkOq3_FurM
    Lesson 11 - Routing with Waypoints your create
    http://youtu.be/qB8N7nAGb_0
    Lesson 12 - BaseCamp created route and then modify
    http://youtu.be/pFTjsqucHSo
    Check out Nugget # 4 at the bottom after this lesson Easier method with rubber band using the ALT key
    Lesson 13 - Auto Routing using your data
    http://youtu.be/mu4r-ee1XSk
    Lesson 14 - Adding a stopover and your time element
    http://youtu.be/MJbI5STi7uo
    Lesson 15 - Common routing errors and how to avoid them
    http://youtu.be/uS93soMx0Mg
    Lesson 16 - Shared Data Files Conversion to GPX format
    http://youtu.be/pnQSKZJd5So
    Lesson 17 - Garmin POI Loader moving data to your GPS unit
    http://youtu.be/uGvgv8mVPPw
    Lesson 18 - Garmin Custom Waypoint Symbols
    http://youtu.be/AuMFEzGNv3Q
    Lesson Nugget 1 - Making your map larger and more controls.... short video. http://youtu.be/s1cD2v3xSKk
    Lesson Nugget 2 - The best accessory for Garmin BaseCamp is the Mouse with center track wheel...as this video shows... Less than 2 mins.. http://youtu.be/R5ZBd04MoWI
    Lesson Nugget 3 - How to extend a saved routed your created. I offer three methods...I hope to plant an idea that you may use. http://youtu.be/sO45PNp5Jns
    Lesson Nugget 4 -The "ALT" key will make using the "Rubber Band Routing" method easy and simply and will use less keystrokes to edit data.
    http://youtu.be/QiVT1QlvHEg
    MOA Ambassador, Member of AL, GA and Chattanooga Clubs, MTF Gold member and BOD.
    2011 R1200 GSA (My Radio Flyer) 75 R90/6 with Velorex sidecar
    My annual charity event: http://www.echbenefit.smugmug.com/
    " Oh Lord I pray, Let me live long enough to do everything they say I've done"
    look out!!! Visian's Avatar
    ATL/WNC
    Don - do you have to speak Alabaman to watch these videos?
    Seriously - good work on these
    (Have you tagged them so they're easy to find on YouTube?)
    Ian
    __________________________________________________ ________
    '67 Trail 90 || '86 R80 G/SPD+ || '97 F650ST || '00 1150 GS || '06 HP2e
    Registered User RandyBailey's Avatar
    Oct 2009
    Prescott, Arizona USA
    Don, I just got a new bike with a NAV V GPS. I just downloaded BaseCamp and will use your videos to learn the program. Thanks for your tutorials!
    2013 R1200RT
    AMA Life Member
    Iron Butt Assn #39345
    AZ Beemers Touring Assn
    Aug 2005
    From NW AL to WNC
    Quote Originally Posted by Visian View Post
    Ian
    Ian, When I started I wanted to share with the motorcycle community and really didn't have a clue about the interest or much about YouTube, therefore I chose to share with forums that I am member... POI Factory, MTF, local clubs...but after Dan mentioned the videos in the Q&A part of the presentation when someone ask if there was a "BaseCamp tutorial for dummies" He recommended my series.. ... Now I can take that several ways.... and several ask for the links after the session, I decided to include them here... I still prefer to answer questions about BC issue on my forum rather than hopping around to many forums.
    I also have the Learn Garmin BaseCamp forum as well with some great guys helping.....and I have several that have subscribed to my Yourtube channel...
    Got couple sessions scheduled, Curve Cowboy Reunion next week in Chattanooga and another session in September at Ironhorse with MTF.
    Now, you don't have to speak Alabaman, but you must like boiled okra and cornbread and of course grits. Oh, I can't talk any slower on the videos either....
    I must admit this has been a learning process for me as well, but a collection of ideas from many folks across several forums.
    Just hope it help someone get over the learning curve... Dan did it for me out in Salem last year...where the idea was born..
    Aug 2005
    From NW AL to WNC
    Quote Originally Posted by RandyBailey View Post
    Randy, hope they do help... the Nav V is loaded with many great features. During the MOA Rally in St Paul, Dan Townsley gave a presentation of BaseCamp and the Nav V ...
    With you Nav v connected and BaseCamp and the V do the tech handshake, your ready to open many of those features.... Hope these tutorial will give you a start with this great mapping software... BaseCamp is getting better with each update and I can attest they do listen to ideas about issues and bugs on their developer's page...granted the updates do take time but I have seen two updates that my group suggested.
    Aug 2005
    From NW AL to WNC
    New Version , please read link first for requirements!
    Update: please click and read the link....
    This version may not support Window XP.....
    http://www8.garmin.com/support/downl...ls.jsp?id=4435
    Changes made from version 4.3.5 to 4.4.1:
    Added notification that eligible devices can install maps on the desktop using Garmin Express
    Added ability to create and manage areas to avoid while routing
    Added properties (and shading) for public land survey types
    Added progress bar in the data list for downloading BirdsEye
    Added progress bar on the BirdsEye wizard for downloading BirdsEye
    Added way to activate BirdsEye subscriptions within BaseCamp
    Added ability to go back on the BirdsEye wizard dialog and select a new area (subscription only)
    Added option to disable imagery display in the map views
    Added ability to mark a geocache as unattempted
    Added some additional waypoint symbols to be more consistent with newer nuvi and zumo devices
    Added Duplicate List and Contents menu option
    Added a column in the data list for waypoint category name
    Added map context menu option to search for the most recently used search category
    Improved response time when populating the list of Birdseye providers
    Changed how nearest area results are displayed on the map when hovering
    Changed to ask if the waypoint should be shared between routes when splitting a route
    Changed to preserve the settings in the print page settings dialog
    Changed the default behavior of the 'recalculate routes to match maps on device' option. This is now only enabled by default for zumo devices.
    Fixed problem with marine heights being displayed incorrectly
    Fixed issues when reading GPX files that contain invalid times
    Fixed odd rendering on newer City Navigator maps
    Fixed issues with inconsistent track stats
    Fixed Select All in lists not selecting the last item
    Canada and the Alps
    I have come across Base Camp and I still do not know what it is and what it will do for me. What is its prime purpose?
    You might start off (edit) your first post with an explanation of that.
    Aug 2005
    From NW AL to WNC
    Without even look at one of the lesson video tutorials, one who have to just read the titles of the lessons (18+) to get an idea what Garmin BaseCamp is all about... A mapping Software program by Garmin for Garmin GPS units.
    Another would Google Garmin BaseCamp (http://www.garmin.com/en-US/shop/downloads/basecamp) to get a commercial explanation of the software. This software has been around for several years and will replace at some point MapSource and since Microsoft Trips and Streets is to be phrased out, this is the choice of many that use and own Garmin GPS units.
    As you handle applies... GobalRider...I would think you need some type mapping software compatible for around the world... Garmin BaseCamp is used around the world with the proper maps.
    Hope this is helpful!
