Page 2 of 5 FirstFirst 1 2 3 4 ... LastLast
Results 16 to 30 of 63
Thread: What Homemade Accessories, Gear, Tools, Improvements, Clothing Have You Made ?
  1. #16
    May 2008
    B.P., MN
    R90S side stand
    Side stand was a bit wiggly, leaned too far, could barely push it out with left foot, and then always wonders if it was extended before bike fell over. So, modified it so I could find it and push it out with left foot, stands up a bit straighter, whatever. Seen others doing the same thing, can't remember where or when. Name:  DSC_0015.jpg
  2. #17
    May 2008
    B.P., MN
    Used a stainless bolt with lock nuts, some tubing, some 12 gauge aluminum and part of an old tire tread. So far haven't broken a leg.Name:  DSC_0016.jpg
  3. #18
    Registered User Moto316's Avatar
    Nov 2007
    Phoenix, AZ
    A tool for removing the front axle on a 1200GS. It's just a bolt with a 22mm head and two nuts. Use some Loctite and jam the nuts together. Cost, about $1.
  4. #19
    Quote Originally Posted by Moto316 View Post
    Nice!
    Cobbled up "special tools" are the best.
    Mike Marr
  5. #20
    Sep 2008
    Planet Earth
    Tool Pouch
    The took kits on my Airhead and K-bikes were always good. But, when I purchased an Oilhead, the tool pouch was close to worthless. So, I made my own out of waterproof denier. Added lots of tools to the new one. Fits perfectly in the tail piece. Next time I would make it with one velco strap instead of two. Maybe a difference color too.
    Here is the original BMW tool pouch on top of my home-made one
  6. #21
    13278
    Apr 2006
    Near Lynchburg, VA
    Homemade
    Make your own package/luggage straps from 1" wide thin nylon strap material and inexpensive plastic ends in custom lengths to suit. One end is fixed and the other is adjustable. Minimal (hand) sewing required and these straps will cinch tight and hold tight and never loosen. Lightly secure the strap after the plastic cinch. Make them long and cut off later.
    Plastic ends are 50 cents +- (get the best you can find) and strap material is cheap per foot.
    Both straps and ends are available at good hiking/outdoor equipment stores and maybe good hardware stores.
  7. #22
    rabid reader dbrick's Avatar
    Santa Cruz CA
    That is very elegant! It is much simpler than steel hex stock welded to an old 10 mm socket that I put together.
    David Brick
    Santa Cruz CA
    2007 R1200R
  8. 08-15-2014, 03:57 PM
  9. #23
    Jul 2007
    THE BIG SKY
    Extended the chain guard on Annie's new F800GS. I used the heavy rubber from an old aftermarket mud flap; cut it to size, and then heated it with a heat gun and rolled it on a piece of pipe to give it the curl I wanted. It greatly reduces the amount of goop that gets thrown up on the luggage and rear of the bike. Next time I might even use matching screws to afix it.
    Kevin Huddy
    Tm Pterodactyl MT Outpost
  10. #24
    13278
    Apr 2006
    Near Lynchburg, VA
    Homemade
    Bead breaker made out of used wood (2x4's and 2x6) and used hinges. Cut 45 degree angle on 2x6 that pushes on the bead, but the jury is still out on whether it helps. In stored position it only takes up 6"x6"x6'. This prototype works fine, but lever could be stronger than spruce as in pine or metal.
    Its on "the list" to change levers one day.
  11. #25
    Debbie's Servant Lee's Avatar
    May 2003
    SW Iowa
    I had a friend cut down a spark plug socket to use as a front axle tool.
    Lee
    2016 R1200RS
    MOA # 30878
  12. #26
    neanderssance man sedanman's Avatar
    Jul 2011
    Pawling NY
    A very clever idea and sanitary execution!
    Paul
    Stop wrestling with your motorcycle, dance with it.
    2011 R1200RT Traded
    2014 R1200RT fully optioned
  13. #27
    May 2003
    SW Iowa
    When I changed out the fuel quick disconnects I saved one of the plastic ends to make an easy and clean way to drain the tank.
    Lee
    2016 R1200RS
    MOA # 30878
  14. #28
    May 2013
    PEI Canada
    I made a sidestand plate out of a piece of 1/8" aluminum, just three bolts around the edge with the washers and nuts overlapping the original stand on top. It's been on for 20.00km, works great and didn't involve mutilating my R1200RT.
  15. #29
    Registered User motocamper's Avatar
    Sep 2010
    NE Pennsylvania
    Camping rack for two up
    Greeting
    We like to camp. The RT top case was not designed for camp gear. The the top case alone weighs a little over 22lbs and holds just 22lbs. I replaced the top case with a camping rack made of scrap Kydex. It may not be pretty but it works better than tying everything around the side cases and top case. The rack and hardware weighs around 5lbs, the yellow bag contains all of our camp gear and weights about 40lbs. The RT weights 700lbs fully fueled with all of our gear and clothes for 2 weeks.
    Jet and I
    The rack with out gear. The bed is 13"x26" back rest is 12"x13" The strip in the center is a stiffener, helps when bag is not in use. The 1/4" 20 screw sticking up are for mounting. It take about one beer to mount the rack.
    rack 2
    The underside mounting bars are 1"x1/4" AL drilled and tapped for 1/4" 20. We have about 40,000 miles on the rack and it has never loosened.IMG_0002
    Underside mounted view.
    IMG_0015
    Side view the center strip is only glued on the bottom.
    side
    Front view to give you an idea of the width.
    IMG_0029
    Tony
    We're not here for a long time
    We're here for a good time HUEY LEWIS
    2007 R1200RT, 2014 R1200rt
  16. #30
    Apr 2008
    SW Ohio
    Reversed the hinges and Home Depot to the rescue for the latch on the 22L top box
    1987 K75S
    Original litter
    Original owner
    2012 Ural Gear Up
