Page 1 of 5 1 2 3 ... LastLast
Results 1 to 15 of 63
Thread: What Homemade Accessories, Gear, Tools, Improvements, Clothing Have You Made ?
    13278
    Apr 2006
    Near Lynchburg, VA
    What stuff have you made out of need, necessity or just for the fun of it to improve your bike or working on it? I've seen many homemade saddlebags, fairing lowers and so many ingenious things, not to mention the "knick knacks", I can't remember them all. I always enjoy seeing them. Most people are proud of the things they make and are fun to speak with.
    I've tie wrapped GPS suction cup mounts to cockpits, made brackets for side view spot mirrors, and made homemade looking functional mud flaps, just to mention a few. I consider myself an amateur novice "piddler" after seeing some of the things out there. There are some very talented riders/enthusiast making things. I hope you show your stuff.
    John Britten poured an engine casting in his backyard and Burt Monroe cast his own pistons in the sand at the beach. I once saw 2 young riders on well used /2's at a rally, that appeared to have gotten together, not quite early enough to have made 2 sets of plywood panniers. Each rider seemed extremely proud to have a right one on one bike and a left one on the other, although no tops. Once I saw a 2nd paddle throttle assist on a left grip also. Huh?
    Pictures help a lot and are not too difficult to add (I did it once). Please tell us about your stuff.
    Charlie
    Apr 2008
    SW Ohio
    OK, I'll start. Always liked the practicality of Bungee Buddies but hated their looks. Made these from some wire coat hanger and pop rivets.
    1987 K75S
    Original litter
    Original owner
    2012 Ural Gear Up
    Calgary
    Lots of home made farkles added to my bikes over the years. Some of the most recent stuff for my F800GS.
    Bar risers to work with the Steering damper mount.
    Fog light mounts to fit the Alt Rider crash bars
    Pelican case top box mounts.
    Ed Miller, Calgary, AB
    2008 K1200GT, 2009 F800GS
    I can't wait to retire and have a fixed income. The one I have now is always broke.
    Pismo Beach, CA
    having a mill for DIY projects is just so.. .. unfair.
    Lew Morris
    1973 R75/5 - original owner
    1963 Dnepr
    13278
    Apr 2006
    Near Lynchburg, VA
    Homemade
    Spot mirror mounts made from an old aluminum clipboard. Used the small adjustable spots that are still under $5.
    Tie wrapped metal clothes pin holds face shield squeegee when not in use. It was made with old wiper blade, elastic and Velcro to keep from losing. Very functional and a lot cheaper than the "real squeegees " that I lost a lot. Never found the right glue.You also had to buy 3 in a pack and only one size ever worked for me.
    Oh, and I've noticed as in Post #3, the nicest stuff usually comes from the cleanest shops. I need to clean the shop, although I doubt that will help.
    It's a way of life! oldnslow's Avatar
    Oct 2011
    Ash Grove, MO
    Heated jacket liners. 75 watts. Total cost was 30 bucks for two of them. made them 4 years ago, and are still working just fine!
    Mike Davis
    "Old n Slow" It's a way of life!
    1985 K100RT
    1998 R1100RT
    Calgary
    Quote Originally Posted by lmo1131 View Post
    What about a lathe? I have one of those too.
    It certainly is a game changer in the fabrication of things. I only recently got them; I did a lot of hacksaw and file work in the past.
    Sent from my Nexus 7 using Tapatalk
    Version 2 with improved mounting (because version 1 fell off after a year of use).
    I went overboard with the sealant because it was the end of the tube with too much to throw away but not enough for another job.
    Braz J Brase's Avatar
    Jan 2005
    Central Indiana
    Side case "chuck wagon."
    Quote Originally Posted by J Brase View Post
    You have Weed in your chuckwagon.
    Mike Marr
    Nov 2011
    Central Ohio
    Quote Originally Posted by motorradmike View Post
    Without the weed he would not be hungry enough to need a chuckwagon...
    Larry
    2006 R1200RT
    13278
    Apr 2006
    Near Lynchburg, VA
    Homemade
    Must be dessert for Colorado camping ?
    "J" certainly seems to well stocked/organized. Well done !
    Mansfield,MA
    Vario Case latch safety straps.
    Mod Squad
    2009 F800GS 1994 TW200
    Mar 2012
    Riggins, ID
    Electric Vest
    In the past I've made a heated vest. I took a nice vest that had a lining, spit the seam along the bottom, removed the resistor wiring from an old electric blanket and used ten feet of it (trial and error), turned the vest inside out from the split seam, laid the wire in the pattern I wanted, held it in place with Stitch Witchery, soldered a plug to the end of the resistor wire accessible through my left vest pocket, turned it back right side out and sewed up the split seam. Then just wired he bike with a fused switch and plug to match the vest. Worked well for many years.
    Gary Phillips - #6322
    '77 R100/7 Dirt Hack, '83 R80ST, '85 K100RS w/EML, '00 R1100RS
    Here's an easy one I did to lock two helmets.
    Attach some steel cable to the underside of the front seat half.
    There's a handy hook already under the rear seat half.
    Helmet locked to bike.
    __________________________________________________ __________________________________________________ _________________________________________
    And here is one I did that's not so easy but it's still one of my favourites. I can't always see the RID gear indicator easily so I put in a nice bright blue one where the ABS lights go(if you have ABS).
    Farkle
    Mike Marr
