Results 1 to 7 of 7
Thread: more mirror for a RT
    Feb 2014
    When my rt is loaded I especially would like more rear view mirrors. I'm thinking of this one screwed to the plastic fairing from underneath to extend beyond the almost useless orginals.
    https://www.denniskirk.com/parts-unl...6.prd/3976.sku
    RT in NC
    Jun 2013
    What year? Wunderlich offers new clutch and brake brackets with extensions for mirrors. http://www.wunderlichamerica.com/mot...C/3272971.html. These only work for the 2014s. There might be others available for different years.
    Buck in Greensboro, NC
    2013 R 1200 RT Midnight Blue - traded, 2014 R 1200 RT Ebony Metallic
    Apr 2012
    Los Angeles, CA
    Some people put GS mirrors on. They mount to the handlebars and come up and to the outside, on either side of the windscreen.
    2000 R1100RT / 1987 K75C (RIP) / Santa Clarita, CA
    Registered User frenchnew's Avatar
    May 2011
    Prevost (30 miles north of Montreal), Quebec, Canada
    here are the Wunderlich mirror adapters for R1200RT up to model year 2013;
    http://www.wunderlichamerica.com/mot...00055-246.html
    I have those on mine with additional mirrors adjusted to complement the OE mirrors so to give me a wider field of view.
    2011 R1200RT Triple Gray, ABS, ASC, ESAII, TPMS & Alarm.
    Wunderlich Engine and Rear Prot. Bar, Oil Cooler Guard, CSS Tank Pads, Paralever Slider, Mirror Adapters & Flash Mirrors,
    Integrated GPS Mount & Touratech Zumo 660 Locking Mount, Russell Day-Long Seat.
    2009 R1200RT beemeup's Avatar
    Portland, Maine
    RT Mirrors
    I have a 2009 RT and found that I couldn't see anything behind me when I was fully loaded with gear for touring. I solved the problem by installing
    K1200RS mirrors which screwed in perfectly to mounting holes by the clutch and brake levers. If you have the holes for this on your RT you are all set. I added blind spot mirrors to the upper corner of these and they work great. Here is a link for the mirrors:
    http://www.ascycles.com/detail.aspx?ID=1792
    Don't forget to order the nuts and the washers for these if you choose this route. Oddly enough,
    they are sold separately.
    Good luck.
    Registered User Dann's Avatar
    Dec 2013
    Laval, QC, Canada
    Quote Originally Posted by beemeup View Post
    Good luck.
    +1 Did the same with my 07 RT
    Daniel
    If you can park it, and not turn around to admire it before walking away, you bought the wrong one.
    R1200RT 2007 - IBA # 56396
    Registered User Kenn45's Avatar
    Aug 2003
    Edwardsville, IL
    Plus 1 on the K1200RS mirrors. I have had them on my 2007 RT since new. They fit perfectly and work great.
