Results 1 to 15 of 16
Thread: Aux brake lights
    Registered User COULTER's Avatar
    Jul 2014
    Nevada City, Ca
    Aux brake lights
    Hello all.
    Like many of us I get very nervous when being tailgated. I'm considering adding a flashing auxiliary brake light from Hyperlite ( http://www.hyperlites.com/ ) on my 2010 R 1200RT.
    I've very little electrical experience and wondering if anyone can tell me:
    (a) if they have one how they like it..... and
    (b) if you installed it yourself how difficult it may have been to do so it.
    Many Thanks to all who reply
    Coulter
    Coulter
    Nevada City, Ca
    2010 R 1200RT
    IBA# 5819 61996's Avatar
    Mar 2014
    Apple Valley, MN
    I have these: http://www.run-n-lites.com/prod-LiteBuddys.html connected to this: http://www.signaldynamics.com/backoffwigwag
    I am very satisfied with the results.
    The instructions are straight forward and if you follow them you should not have a problem.
    Good luck!
    Joe
    If life throws you a curve; lean into it.
    Jul 2007
    THE BIG SKY
    Quote Originally Posted by COULTER View Post
    Hello all.
    Coulter
    I've installed 6 sets of HyperLites. Pretty easy to do with straight forward instructions. Will help if you have a multi-meter available.
    Kevin Huddy
    Tm Pterodactyl MT Outpost
    Mar 2011
    socal
    I've installed about a dozen sets of P3 lights, on both BMW's and other brands
    Jerry has very good instructions online for most bikes. Install is pretty simple, generally no more than a hour
    One suggestion I always follow is to solder and shrink wrap as many of the connections as possible
    Your friends will be amazed at the difference these lights make
    Registered User sickticket's Avatar
    Oct 2012
    Dublin, Pa
    I have also installed the Hyperlites on my 2013 R1200RT. Real easy.
    Aug 2013
    NB, Mass
    I used the Skene Design P3 setup along with the saddlebag mounts, also wired the topbox light into the controller.. Like them a lot. Plenty of light back there now.
    Mike
    13' K1600GTL
    St Paul
    hyper lites
    I love them. The first time I used them the car that was tailgating me backed off real quick. I also put on the modulating led's on the front. Once I came up behind a car and the car pulled over and the driver was reaching for his wallet. I had just seen him get on a major road without stopping at a stop sign.
    http://www.hyperlites.com/hyperwhite.html
    Hi Coulter:
    This may not be exactly what you're looking for but you might find the thread interesting.
    Aux brake lights
    Welcome!
    Mike Marr
    Jul 2014
    Nevada City, Ca
    Very Helpful
    Quote Originally Posted by motorradmike View Post
    Hi Coulter:
    Aux brake lights
    Welcome!
    Thanks so much - it's quite helpful
    Coulter
    Nevada City, Ca
    2010 R 1200RT
    Boxer n Cruiser jfmoore430's Avatar
    Jun 2006
    Cary, NC
    I added Hyperlites for the same reason.....tailgaters! They now stay well back of me when I flash them! I am very happy with the results. I am no electrician but they are an easy install especially if you go ahead and install a Fuzeblock.
    John
    2011 BMW R1200 GSA
    2009 BMW G650 GS
    vancouver ,wa
    Smile Lights
    Quote Originally Posted by jfmoore430 View Post
    i AM an electrician !!! I have Hyperlites and a flashing LED brake light. I do not get tailgated. Most are easy to install.
    Apr 2012
    Gilbert, AZ
    I've been eyeing a set of Hyperlites flashing brake lights for a while. Which flash pattern do y'all think is most effective?
    2004 R1150RT
    BMW MOA 181289
    Utah 12 - what a road!
    Mar 2014
    Camarillo, CA
    BMW aux light
    I have Hyperlights on two of my bikes and have the BMW Aux lighting on the RT.
    I like the BMW light because it was a very clean install and looks 'right' on the back of the RT.
    No problems with hyperlights on either of the other two bikes, just thought I'd try the OE lighting on the RT.
    2014 BMW R1200RT
    2005 Road Glide - 91,000 miles
    2002 Honda ST1100 - 91,000 miles
    vancouver ,wa
    lights
    Quote Originally Posted by markaz View Post
    I use a three fast flash that then goes to a steady on patten.
    2009 R1200RT beemeup's Avatar
    Portland, Maine
    Hyper Lights
    I've installed Hyper Lights on a couple of my bikes and the install was easy with their very
    thorough instructions. One thing I would add about Hyper Lights is that the guys at the
    company are a pleasure to deal with........customer satisfaction is very important to them.
    I had half a bank of my Hyper Lights fail this spring from an original install that had been done in 2009.
    I called them, they didn't ask how long I'd had them and sent me a free replacement for
    that bank of lights, no problem. I had them in 3 days and were on the bike and working perfectly
    in about 10 minutes. Needless to say, I'm a big fan of Hyper Lights!
