Results 1 to 7 of 7
Thread: Charging BMW communicator
    I have a Schuberth C3 with a BMW communication system in it and would like to know if there is a cord available that allows for charging the helmet system from my 2013 RTs battery. Thanks!
    I have a hot wire to my tank bag and a usb outlight that plugs into a cig adapter. I am sure you could do straight from the bat. Look at http://www.powerlet.com/.
    Buck in Greensboro, NC
    2013 R 1200 RT Midnight Blue - traded, 2014 R 1200 RT Ebony Metallic
    Albuquerque, NM
    You've checked the operator manual I assume and it shows none available from BMW?
    I've found my Communicator good for nine hours fully charged.
    Kent Christensen
    21482
    Mar 2011
    socal
    Can you charge and operate the communicator at the same time?
    Yes, but I am not sure if it prolongs the charge. It takes a while to charge when run down. I charge every evening on a long trip. Then periodically when just riding around home.
    Cupcake greg's Avatar
    Jun 2014
    Central Valley California
    If you can find a place to mount it, one of these works great. I had one on my 2012 GS and it would charge my iPad and phone while in the tank bag. No reason to think it wouldn't charge the communicator while in use as long as you can find a cable that is long enough.
    Greg
    South Central Valley, CA
    2014 R1200RTW, 2010 Yamaha TW200, 1978 R100/7
    St Paul
    Quote Originally Posted by bigmon70 View Post
    In your cubby box on the riight there is a USB connector that you can charge it with. I have used it while I have been going down the road.
