Results 1 to 7 of 7
Thread: Leaking tranny oil through the clutch lever assembly
    Registered User 88bmwjeff's Avatar
    Aug 2004
    Walnut Creek, CA
    The bike: 88 R100 RT. The issue: I'm leaking tranny oil through the clutch lever assembly at the back of the transmission. It's dripping down the clutch lever, but is not leaking from beneath the rubber boot. Although it's not dripping a lot, it's stinking up the whole garage. So, I need to fix it to keep the better half happy. Should I replace something else other than the rubber boot?
    Jeff in W.C.
    1988 R100 RT (the other woman)
    "I got my motorcycle jacket but I'm walking all the time." Joe Strummer
    Administrator 20774's Avatar
    The '88 has a different arrangement than the earlier bikes. According to the diagram, the boot is the only sealing part...nothing on the inside.
    http://www.realoem.com/bmw/showparts...86&hg=21&fg=51
    Have you checked that the vent bolt that holds the sped cable in is clear? You can blow it out with compressed air or clean it out with a wire.
    Registered User PAS's Avatar
    Jun 2011
    N.E. Ohio
    The push rod does have a seal (in the end of the input shaft)that keeps oil from migrating towards the clutch. This wouldnt be the problem.
    Check the neutral switch and especially the drive shaft boot for leaks. Oil leaks have a way of moving around.
    Aug 2004
    Walnut Creek, CA
    Quote Originally Posted by beemerphile View Post
    I'll give it a quick look next time I'm out there.
    Quote Originally Posted by PAS View Post
    I don't see how the neutral switch or the drive shaft boot can cause oil dripping down off of the clutch lever at the rear of the transmission, since both are below the clutch lever.
    Jeff in W.C.
    Jun 2011
    N.E. Ohio
    Quote Originally Posted by 88bmwjeff View Post
    My clutch lever end is under the driveshaft boot. Perhaps yours isnt.
    Aug 2004
    Walnut Creek, CA
    Well, it's been a while since I've looked back there, and from the left side of the bike, it didn't look that way. But yes, it's underneath the driveshaft boot. Thanks for the suggestion. For better or worse, the driveshaft boot is dry--na that's better. Replacing that boot is a royal pain.
    Jeff in W.C.
