Results 1 to 4 of 4
Thread: 92 R100RS clock covering
    Go Leafs Go CANADIANSTEVE's Avatar
    Nov 2004
    Voluntown CT
    For some reason the plastic piece covering the clock face is becoming clouded over ... not moisture but more like the material is degrading. Clock works just fine, just can't see most of the face ! Anyone experience this ? How does the clock itself come out of the instrument panel ? Thanks.
    Steve
    steve now in CT
    moved from Toronto
    92 R100RS
    Fenwick, Ontario Canada
    The clock is held in place with 2 plastic knurled nuts and a cross bracket.
    You have to get in there and unscrew the nuts an the take off the bracket and the clock will come out of the dash.
    Small hands will help! Pay attention to the wires as you remove it. The clock does not come apart, so a replacement must be found. VDO has similar units at a fraction of a BMW prices.
    Knights of the Roundel #333
    Feb 2004
    Monroe La.
    I had the clock and volt meter do the same thing after some cleaner I used.
    1975 R90/6, 1980 and 1982 R65, !959 TR3A Triumph Car
    Registered User PAS's Avatar
    Jun 2011
    N.E. Ohio
    The clock on my 81 RT has a dusty look to the inside of the glass also. They are sealed.
