Results 1 to 7 of 7
Thread: Pin or bolt? 73 R75/5 LWB
    Apr 2012
    Pulaski VA
    While riding today, I lost about half of the action in my clutch lever. I was thinking that the throwout bearing was failing. I was close to the interstate so I went straight home. Turns out the fastener that holds the clutch linkage to the clutch pushrod? had worked its way out and was missing. I looked in my manuals and the parts fische but didn't see it. Can anyone help a brother out?
    Registered User dmftoy1's Avatar
    Mar 2012
    Lexington, IL
    Look on snobum's website. There's a $5 upgrade for that problem. I missed it when restoring my 74 R90/6 and it cost me serious bucks when I broke an ear off on the back cover of my tranny.
    Registered User kioolt's Avatar
    Maryland
    Are you talking about part 13 in this drawing?
    http://www.realoem.com/bmw/showparts...71&hg=21&fg=51
    2004 R1150RT 171,200 miles , 1991 K100LT 128,700 miles, 1982 R100RT 106,900 miles
    Total 406,800 BMW miles
    AMA,BMWRA,BMWMOA
    The cheapest thing on a BMW is the nut that connects the handlebars to the seat.
    Apr 2012
    Pulaski VA
    Yup, that's it! Thanks!
    Registered User godfather's Avatar
    Oct 2006
    Cadillac, MI area
    I replaced mine with a new and improved version from Max's (I believe) It has a shoulder/head that prevents it from falling out if you should somehow loose the retaining clip. Worth the few bucks IMHO.
    Attitude is everything!
    08' V-Strom 650 great light weight tourer
    Airmarshal-IL James.A's Avatar
    Sep 2013
    central Illinois
    On a /5, 4 speed transmission, there should be a cotter pin that fits thru a drilled hole in one of the cast ears on the back cover. That cotter pin fits in one of the grooves turned in the pivot pin to lock the pivot pin in place. In many cases, when the pivot starts to come out, a bind developes and one of the ears breaks off. If your bike has a later model 5 speed transmission, that is where the retaining circlip is used. Either way, a pivot pin that is migrating is never a good thing.
    I have a /7, and the way I handled mine as I despised the clip holding the pin in place (and also didn't trust it) was to purchase a Stainless steel 8mm hex bolt with no threads below the head for about 1-1/4" (the width of the ear OD) and then sawed it off, and used a self locking nut on it to hold it in place. I made sure that when tightening, not to tighten down on the "ears" of the trans, but let the locking nut do the locking.
    Has worked perfectly for thousands of miles. No clip to hastle with!
    "The difference between death and taxes is that death doesn't change every time congress meets." - Will Rogers
