I'm wondering if I can get some advise on a recently purchased a R69S. It appears that my carburetor float needles are not sealing properly as fuel leaks from the idling mixture adjustment screws after the engine is shut off and for a while after I shut the fuel petcock. Is that a correct diagnosis?, and if so would that necessitate a carburetor rebuild? Would this be relatively easily done by a fairly handy person?
An additional problem I've noticed is that while idling the right cylinder head and exhaust pipe gets much hotter than the left side. I've checked the valve adjustments and will check the timing. Does any one have other suggestions (fuel mixture?)?
Thanks for any advise provided.
